September 12, 2025, 10:10:54 AM *
Author Topic: Clutch Plate B  (Read 7101 times)
TTG53#1717
Far West Texas
« on: March 31, 2025, 10:53:31 AM »
My ‘97 Standard clutch slips at 2500 RPM + under relatively normal throttle.
I was running Mobil 1, did a detergent flush and went back to Honda oil.
That did not fix the issue.
I will be doing the slave cylinder rebuild and system cleaning this week and hope that fixes things.
Too include the little bleed hole in the master.
No problem with lever position  to indicate rivet failure but of if I do need to replace that, is this the correct part to order ?
https://www.partzilla.com/product/honda/22322-MZ0-000?ref=aed07ed4283fe66dcda10a563b5a3ba1e8b39067
Tim
‘97 Standard Purple/White
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
« Reply #1 on: April 01, 2025, 06:15:21 AM »
Yes, that looks correct.
Can't believe how much that costs.
But I don't remember what I paid over 20 years ago either. Roll Eyes
Usually the main symptom of rivet failure is felt at the clutch lever and clutch slipping can be a symptom, but not as common.
Have you had the rear wheel off lately and checked out the pinion cup?
Good luck, hope you solve it.
F6Dave
« Reply #2 on: April 01, 2025, 07:43:18 AM »
$50.08 from Honda DirectLine back in 2010. I keep images of all my old orders for reference.
I've always wondered if you could replace the rivets if none were available. It's definitely not worth your time if you can get a new one for $84.
TTG53#1717
Far West Texas
« Reply #3 on: April 01, 2025, 12:38:09 PM »
Thanks for your replies.
I can give plenty of advice on 50 and 70 year old Harleys but now that I’m retired and on a budget I need to know about Valk stuff before I waste any money. I bought this bike new thinking I’d only have to do scheduled maintenance well into my advancing age. Quite a rude awakening to have this clutch slipping issue and thanks to some previous reading here I know I can tiptoe through the troubleshooting steps before getting into the oil.
I did have the rear wheel off last summer for a new tire and everything looked fine.
I have a complete machine shop in my back yard that I have used modifying my HDs but I’ll buy that disk before I try to make and install rivets.
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
« Reply #4 on: April 01, 2025, 12:52:08 PM »
yes that is the damper plate. u will need the plate on either side it since they will be damaged by the rivets.
that is all I replace on my '98.
in '97 the Valkyrie Clutch plates are an upgrade compared to the '88-'96 Goldwing GL1500s. '97 to '00 all got the upgrade. actually it was only two plates that are different.
The clutch packs are know to last 300+k miles in the heavier Goldwings while pulling trailers. I bought a spare basket assembly on ebay, pre-'97 which had over 300k miles on it. I measured the plates and they were all within Honda specs.
check part cost here. usually about the same, but only have to spend $75 for free shipping
https://www.rockymountainatvmc.com/oem-parts/Honda
« Reply #5 on: April 02, 2025, 05:04:57 AM »
Ron Ayers is where I buy all of my parts.  They are $81.33 this morning.  I would buy the plates on either side of the dampener plate, due to any damage the rivets might have caused.
Hmmm....  Pressure plate no longer available...... But the clutch spring is.
https://www.ronayers.com/oemparts/a/hon/506c2e73f870023420a31af2/clutch
Hay  Cool
TTG53#1717
Far West Texas
« Reply #6 on: April 04, 2025, 08:26:30 AM »
Thanks for the additional responses and suggestions.
Some places in stock, some on back order. I’m thinking I should buy now and not take any chances of losing out altogether. I can buy a radiator hose and some exhaust gaskets to get free shipping. cooldude
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
maniscar
VRCC #2225
Southern NH
« Reply #7 on: April 05, 2025, 07:26:17 AM »
I'm having the same slippage at 2500+ RPM's, but mine is a 2003 w/68K miles. Gears shift fine, but do notice disengagement/engagement with the lever way out, more than usual lately; like just barely squeezing it. I'm hoping it's the slave cylinder too.
  Rich
2003 Valkyrie Standard
TTG53#1717
Far West Texas
« Reply #8 on: April 26, 2025, 07:09:01 PM »
Update…
I ordered the plates from Partzilla. Shipped out the next day.
I scheduled my slave cylinder work for the day they were to arrive.
The day before scheduled arrival, a USPS track found the package in Nashua NH. The 5th east coast sorting facility that was further and further from far west TX. Vanished from tracking for 2 days.
I put the bike up on the lift and then read the FSM. My lift adapter rests on the side stand bracket. Did all the wet work, got the slave loose but just couldn’t clear the one screw. Back on the ground, found the perfect pieces of wood for under the right engine guard, removed the side stand bracket and then found a reasonably clean and fully functional slave. Not my problem. I’m guessing it’s rivets.
I put the side stand bracket on the mill and removed material to allow clearance for future slave maintenance.
The PO finally delivered my parts yesterday after an 11 day voyage. Now to find the time…
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
« Reply #9 on: April 27, 2025, 04:33:11 AM »
I salute your ingenuity, but wonder about removing structure from the side stand.
Honda engineers went very far to reduce the weight of these bikes as shown by the triangular part missing.  They left what was decided was needed to support the bike and you've reduced that.
I hope you never have an issue, but to compromise the stand to make servicing a part once or twice in its lifetime seems suspect.
« Reply #10 on: April 27, 2025, 07:03:15 AM »
When I use my bike jack for any extended work or hard wrench pulling, I get out two jack stands and put them under the forward engine guards, then let the jack down just enough to get the bike equally supported by both jack stands and the bike jack.  At that point the bike is rock solid and I could trip and fall onto it, and it's not going anywhere.
TTG53#1717
Far West Texas
« Reply #11 on: April 27, 2025, 01:54:37 PM »
It’s a family of parts item and fits 82 different models, to include Tourers which can weigh literally hundreds of pounds more than my little ‘97 Standard. I’m sure it’s been given an added percentage of safety margin above a fully loaded Tourer so I have no qualms whatsoever about nibbling away some clearance from a very nice forging. I did mutter a few expletives about the Engineers who chose that particular design with zero consideration towards maintenance and Mechanics.
I’ve worked with some incredible Engineers. I’ve also been responsible for seeing a few join the unemployment line. Notches on my file handle.
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
TTG53#1717
Far West Texas
« Reply #12 on: May 04, 2025, 09:25:10 PM »
Watched a couple vids and decided to order some more parts before I delve into the cases.
I have an old set of jack stands that I’ll modify to work with the engine guards. Thanks Jess for giving me some shop time.
https://postimg.cc/gallery/5xmdCkR
TBC…
Tim
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
« Reply #13 on: May 05, 2025, 03:20:49 AM »
My jack stands are exactly like yours.  Except not orange (LOL).
I needed no mods (?).   Unless you're trying to go taller.
« Last Edit: May 05, 2025, 04:04:03 AM by Jess from VA » Logged
TTG53#1717
Far West Texas
« Reply #14 on: May 13, 2025, 07:44:26 PM »
So now my 2nd parts order from Partzilla has also gone astray. Took them 3 days to ship and now it’s missing in the mail.  Very mysterious.
My jack stands are ready as of today but we’re being buried in dust and 40+ mph winds for the 30th + time this year. This nano dust gets everywhere.
I’m really gonna have to get my work area cleaned up and hope I can keep it that way before I open up the cases.
Regarding the jack stands… I never really trust things that don’t clamp or have a positive fixation. I have equipment, so I make it into something I know won’t surprise me. Those are now dedicated Valk stands.
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
Dirty Dave
Montreal, Canada
« Reply #15 on: May 15, 2025, 03:19:34 PM »
Some good ideas to stabilize the bike.
I used a wheel chock and a couple of straps from the ceiling on the  handlebars.
« Reply #16 on: May 15, 2025, 04:28:21 PM »
Kinky.   Grin
« Reply #17 on: May 15, 2025, 07:26:17 PM »
never put straps to handlebars, always put them to the triple clamps.
TTG53#1717
Far West Texas
« Reply #18 on: May 31, 2025, 02:51:45 PM »
The PO found my shipment. Partzilla sends stuff in the highest quality box with a perfect label. I simply can’t fathom how the PO sent both my shipments so far astray.
I have what I need but in the interim my eye surgeon moved my cataract surgeries to yesterday and this next Monday so now I’m on hold for a few weeks. Just in time for triple digit temps.
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
TTG53#1717
Far West Texas
« Reply #19 on: June 14, 2025, 02:03:30 PM »
Well I had my right cataract done. Was completely blind in that eye for 4 days. Surgeon said it was a “difficult “ extraction. Did not do the left. Also no longer have my perfect near vision. 50 years ago I learned how to sharpen drill bits by hand and could still do that easily. Can’t focus close up to do that anymore. Maybe in time…
Picked up a SERIOUS staph infection in my left elbow from a chair arm in a doctors waiting rooms.
3 hrs from “Gee what’s that” to the ER and two weeks of two different antibiotics. If I had waited overnight I might have lost my arm.
So yesterday I got released to do heavy work and today got the Valk up on the stands.
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
« Reply #20 on: June 14, 2025, 04:27:48 PM »
I don't like that lift setup at all, esp., when working under the unit.
 accident waiting to happen IMHO. but thats me.
I use an atv/motorcycle lift not the table style..
John97
« Reply #21 on: June 27, 2025, 07:56:43 AM »
I use a motorcycle lift as well, not a table but the style you gotta be precise about where the pads hit. Anyway what is it you don’t like about the pictured set up? The stands or what? I’m just curious is all.
TTG53#1717
Far West Texas
« Reply #22 on: June 27, 2025, 08:17:38 PM »
Well, I finally got involved in this endeavor. Once I got the cover off there was NO evidence whatsoever of rivet failure. I guess I’ll just proceed to pull the clutch and do a full inspection. Now I need surgery on my infected left elbow so who knows when I’ll see this done.
The jack stands and wheel supports would survive an earthquake. In my 55 years of working with 400+ pound bikes, I’ve never had a more stable platform. Life is good.
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
« Reply #23 on: June 28, 2025, 03:23:25 AM »
the small foot print support of the wheel/tires. nothing to prevent fore/aft movements. the small block sitting on the jack stand can easily move.  the rear wheel does not have a parking brake, it will move independent of the frame/engine.
750lbs+ in the air.
TTG53#1717
Far West Texas
« Reply #24 on: June 28, 2025, 09:40:37 PM »
98…The top of the jack stand is machined flat. The aluminum block has two 5/16 studs through it that are threaded 5/8” deep into the top of the jack stand. The bottom block is secured by nylock nuts to that stand and then the top block clamps it solidly to the engine guard side rails. It’s not going anywhere.
The bike was lowered while they were loose so that all four corners of each stand touched and then the clamps were tightened. It’s rock solid. There is a bungee on the front brake lever.
I do appreciate your concern.
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
Dirty Dave
Montreal, Canada
« Reply #25 on: July 02, 2025, 02:15:12 PM »
Fantastic work.
I just crawled around on the garage floor to get the job done.
Half the rivets were gone.
« Reply #26 on: July 05, 2025, 06:35:43 AM »
Just piping in to say in my 25+ years of parking a Valk on jack stands, both just 2 under the front engine guards and 4 using the bag guards, I've never had any issue.
TTG53#1717
Far West Texas
« Reply #27 on: August 24, 2025, 06:55:30 PM »
Well I finally got back to this and while all my rivets are still there, they are all loose and the plates are jangly. I guess I dodged a bullet and will now start to clean, inspect and measure everything before I refit with the new parts and re-assemble .
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
