February 11, 2026, 07:35:19 AM *
Author Topic: Good power source and phone charger location  (Read 1767 times)
Quince
« on: April 28, 2025, 09:03:54 PM »
Wondering where to steal power from and where should I locate the phone charger. Charger/USB recommendation will be appreciated also. Thank you.
« Reply #1 on: April 29, 2025, 04:48:21 AM »
The accessory hookup behind the right side cover.
h13man
Indiana NW Central Flatlands
« Reply #2 on: April 29, 2025, 05:11:59 AM »
I bolted the 12V plug onto the top of the battery cover. My seat function very well to gain access.
« Reply #3 on: April 29, 2025, 07:10:59 PM »
shftr had his just next to the petcock but used it as a lighter
I think if you have an interstate the fairing is the best place
I have one on my handlebar but it is not connected presently.  I unplugged it when I
was trying to trace why the battery kept dying on me
Ended up it was the fog light switch (at least that is my story)   Wink
« Reply #4 on: April 30, 2025, 05:05:22 AM »
I recommend NOT mounting any charger or power point anywhere on the bike. It won’t look as cool with the wires hanging off of it while riding. I have three power point sockets under the seat. My phone charger cable runs into the right side saddle bag. It’s perfect and very convenient for as much as I need to use it
Avanti
Stoughton, Wisconsin
« Reply #5 on: May 04, 2025, 11:16:45 AM »
If you drill holes anywhere in any plastic parts you will be drilling in parts that are no longer available new.
« Reply #6 on: May 04, 2025, 12:44:37 PM »
I’ve drilled a couple holes for needed switches. It’s been years with no regrets. If you’re going to do it, be sure and do it well.
Joe333x
Boston
« Reply #7 on: May 06, 2025, 11:30:02 AM »
Use the 12v accessory wire and use it trigger a relay that's connected to the battery, then you will have a solid 12v switched power source.
https://www.facebook.com/share/p/16XHGQcDCA/?mibextid=oFDknk
