February 11, 2026, 07:35:14 AM *
Author Topic: Rear Axle Tightening Procedure  (Read 1496 times)
Jim Moore
« on: May 08, 2025, 09:26:50 AM »
Got my new tire on, now time to reinstall teh wheel. I *think* the keys is to tighten the axle with the four final drive bolts loose, AND with no vertical pressure on the axle (IE: the axle slides right in). Is that correct?
« Reply #1 on: May 08, 2025, 09:33:32 AM »
YUP: Correct.
Jim Moore
« Reply #2 on: May 08, 2025, 10:29:16 AM »
Thanks.
« Reply #3 on: May 08, 2025, 11:42:52 AM »
And nothing supporting the wheel up in the air not touching the ground and then torque the axle followed immediately by the four final drive nuts
turtle254
Livingston,Texas
« Reply #4 on: May 08, 2025, 01:34:41 PM »
Do not loosen the drive line bolts before you get the axle back in or you will have a hell of a time getting the axle spacer back in!
« Reply #5 on: May 08, 2025, 01:44:34 PM »
If anything, having the four final drive nuts loose makes it EASIER to get all the parts together. I’ve only done this a hundred times over 20 years.
