February 11, 2026, 05:36:12 AM *
Author Topic: What is your Idle RMP  (Read 1988 times)
Quince
« on: May 19, 2025, 09:26:06 AM »
First time I put some miles (Cool on the bike. Last time I ran the engine in the garage for 3-4 minutes but prior to that it didn't run for months. This weekend I finished the new front brake lines and I was ready to test them. I started with half choke, about half minute choke off and engine was idling at 900-1000 RPM. By the time I got back the idle was 1200-1300, obviously hotter engine. Is this normal, do I need to make a longer trip, maybe open it up on the highway to get system purged, and what is Honda recommended RPM, if any, just to know in case I should adjust it?
Thank you
« Reply #1 on: May 19, 2025, 09:40:46 AM »
I run about 750 at idle.  Most recommend 1000 as that is the low end of charging from the alternator.  I don't figure I idle long enough to be concerned with that.
I have put about 320,000 miles on four Valks.  Oops, 400,000 on five.
« Reply #2 on: May 19, 2025, 09:48:18 AM »
tech manual calls for 900-100 rpms.
below 800 rpms and alternator is not charging, meaning everything is running off the battery.
« Reply #3 on: May 19, 2025, 10:04:28 AM »
Mine is set to 900-1000.  It slows a little when the fan kicks on in South Texas traffic, but not too bad.
Hay  Cool
« Reply #4 on: May 19, 2025, 10:40:57 AM »
If you set the idle before it completely warms up it will be too high at operation temperature. Go for a ride  and when you stop set the idle where you want it. Around 900 is totally fine
