February 11, 2026, 05:36:12 AM *
Author Topic: Non used 8 yr old tire  (Read 3038 times)
clanky
« on: May 25, 2025, 02:06:22 PM »
I'm requesting help from the collective.
I just bought a Avon Cobra Chrome tire from Riot Parts for $219, which is around $90 cheaper than the same tire I bought last year.
If I'm reading the date of manufacture code correctly it was made in August of 2017 in England.  Goodyear bought Avon and shut down all the Avon plants in Europe and brought the machines/technology to the US in 2022/23.
Question is should I return the tire because it is 8 years old?  The tire shows no environmental damage (ie cracks in the skin of the tire) but I seem to remember reading about rubber degradation just from age.
I value my life more than $90 savings on a tire.  But I'm by no means a tire expert!
What do y'all think?
Thanks in advance for your inputs!
Matt
« Reply #1 on: May 25, 2025, 02:09:23 PM »
You have no way to know but if it was stored inside in a controlled environment it should be fine. If it was in a hot wharehouse, it's questionable.
da prez
Wilmot Wi
« Reply #2 on: May 25, 2025, 02:44:57 PM »
  Not worth the risk.  Rubber compound hardens with age. Contact them.  Going by memory (?)  I do not think dealers can legally sell tires over two or three years old.
  BTW , if one tire blows , you have one more left.  crazy2 crazy2
                                        da prez
mello dude
Dayton Ohio
« Reply #3 on: May 25, 2025, 04:03:13 PM »
Just for clarity, what is the date code on the tire?  Cool
rug_burn
Brea, CA
« Reply #4 on: May 26, 2025, 07:39:09 PM »
   Just give it the thumbnail test:  take your thumbnail and see if you can press it into the rubber.   If the rubber is hard and has a crust on the outside, then it's time for a new tire.   But If it's still rubbery, then I'd use it, but would proceed carefully until I could can be sure of its grip.   But that's just me, and remembering that tires are expensive, and Avons are especially sweet.
     I think being outside in the elements and sun is what ages tires more than anything.
...insert hip saying here..
« Reply #5 on: May 27, 2025, 05:19:09 AM »
The date code is 4 digits, first 2 digits are the WEEK # and the 2nd 2 digits are the year.  Example  2624 is the 26th week of 2024.
Personally, I would send it back and get them to send a fresh one.
You only have 2 of them and a blowout on either one can be catastrophic.
My $.01875.
Hay  Cool
clanky
« Reply #6 on: May 29, 2025, 01:11:23 PM »
Thank you all for your responses!
It appears that the 2017 date I read was located along the bead of the tire NOT next to the DOT date code.
Upon looking again at the tire sent to me by Riot Parts the date of manufacture was 4023.  Week 40 of the year 2023. So I will be using and wearing out the tire within the next year or two. So the tire will be in the recycle bin by the end of 2026. At the age of 3 years well within online recommendations of 6 year max life of a tire.
I wanted to make sure that I do not disparage Riot Parts by selling me a 7 year old tire.  They did not and I wanted to set the record straight.
Again thank you all for your responses!
« Reply #7 on: May 30, 2025, 05:57:22 AM »
Clanky, that is very acceptable.  4023 is only 2 years old and if kept inside, you will have no issues.  I rode a 5 year old tire, after buying the bike, and the belts started coming apart.  There was a huge bubble on the right side of the tread, not the sidewall.  It rode funny on the way back from work one day and looking at it, I changed it before I rode it again.
Good Luck!
Hay  Cool
h13man
Indiana NW Central Flatlands
« Reply #8 on: June 04, 2025, 05:17:35 AM »
Just checked this site and our rear tire is $224.  Huh?
https://riotparts.com/collections/tires-on-road/products/avon-cobra-chrome-av92-rear-tire-180-70r16-77v
