February 11, 2026, 05:35:37 AM
Throttle Free Play
Topic: Throttle Free Play (Read 2075 times)
dan7uk
Louisville, Kentucky
Throttle Free Play
June 02, 2025, 04:41:00 AM »
I have a 99 interstate. I had more free play in my throttle than I like so made adjustment at the handle bar end with the barrel nut. While I got the adjustment I wanted I notice I have ran out of adjustment if I need to tweak it. How much trouble is it to adjust at the carburetor end? Does the tank need to be removed or is the adjustable assessable?
Re: Throttle Free Play
June 02, 2025, 08:37:24 AM »
first adjustment must be done at the carb connections. adjustment at throttle is for fine tuning.
dan7uk
June 02, 2025, 04:50:33 PM »
Quote from: 98valk on June 02, 2025, 08:37:24 AM
Does the gas tank have to be removed to adjust at the carbs?
June 02, 2025, 04:58:50 PM »
Quote from: dan7uk on June 02, 2025, 04:50:33 PM
No. middle carb on right. u should be able to see the cable adjusters. pretty sure instructions are in owners manual.
dan7uk
June 03, 2025, 04:12:59 AM »
Quote from: 98valk on June 02, 2025, 04:58:50 PM
June 03, 2025, 04:35:29 AM »
If the tank is in the way you should be able to just remove the two mounting bolts and lean the tank to the left to gain access.
