February 11, 2026, 05:35:36 AM *
Author Topic: Aftermarket Ignition coils  (Read 2785 times)
T.O.Jim
« on: June 11, 2025, 06:31:15 PM »
Hi all, first time poster here. I had an issue come up on my ride this past weekend.
I was accelerating on a highway on-ramp when all of a sudden my 98 Tourer got down on power and the engine sounded different. I rode straight home and parked the bike. The next day I fired her up and checked each cylinder’s exhaust pipe to see if there was uniformity. Turns out cylinders 1&2 weren’t getting warm at all. So I’m suspecting ignition coil. I’m going to do a proper diagnostic before I order parts.
And here’s my question- is any of the cheap aftermarket coils any good? I could get a coil from Amazon for nearly a quarter of the price of an OEM. Even a used unit on eBay is getting close to the price of a new one by the time shipping and tariffs are applied (I’m in the GreaterToronto area). My gut tells me I’m best off getting a new OEM, but it’s hard to swallow $200+ for a coil. Anyone here have any experiences with aftermarket coils?
TYIA
« Reply #1 on: June 11, 2025, 07:57:43 PM »
Before spending any money, do as you said and make certain the coil is bad. For #1 & 2 it's the front coil up under the tank ln the left frame rail. A bad connection can easily be the issue. For info purposes, the forward coil of the two by the petcock fire #3&5 and the rear coil of those two fire #5&6. They seldom go bad but does happen.
« Reply #2 on: June 11, 2025, 08:00:14 PM »
the valkyrie coils are the same as the goldwing GL1500 and ST1100, and other honda motorcycles. I did install a set of blackbird coils in my valkyrie, they provide a hotter stronger spark. the two under tank are not a direct fit since they are larger then the valkyrie coils, so made up an extension bracket and longer bolts are needed.  I need to re-install them later this yr after another dyno run.
T.O.Jim
« Reply #3 on: June 17, 2025, 05:54:41 AM »
Hi all, as it turns out, it was probably a bad connection that caused my issue. There was nothing loose, however it probably hasn’t been touched since new. She’s all good now.
