February 11, 2026, 05:36:16 AM *
Author Topic: Excessive play in the wheel hub  (Read 2923 times)
Shima
« on: June 14, 2025, 11:42:23 AM »
I took the rear wheel off my 99 I/S today. The splines on the wheel hub and the final drive seemed ok for a 26!yr old bike. The hub section bolted to the wheel is a little loose with play. Is that supposed to be tight, or have some play in it. Seems like it would cause wear having play. I took a picture, but didn’t see how to attach it to this post. Thanks.
« Reply #1 on: June 15, 2025, 06:04:20 AM »
That’s called the Flange. It is not bolted to the wheel. Just pry it off. DONT MESS WITH THE FIVE BOLTS.
Sounds like you need new dampeners.
« Last Edit: June 26, 2025, 11:10:28 AM by Chrisj CMA » Logged
« Reply #2 on: June 26, 2025, 11:11:15 AM »
What did you discover Shima
