December 19, 2025, 06:53:10 PM *
Author Topic: Question re. Kuryakyn transmission cover.  (Read 1007 times)
« on: June 19, 2025, 05:59:29 PM »
I need a picture of the right side mounting brackets installed for the Kuryakyn chrome tranny cover. I'm having to modify the cover itself due to interference with the reverse engagement apparatus. I've had to reengineer a few things so far just to make them fit or operate so this is no surprise. I know I'll have to cut down the top portion of the cover to allow reverse engagement linkage to function. Now I'm trying to figure out how to mount the bottom half of the cover and it appears I may have to fabricate a new mount to replace the lower L shaped one. TIA
PS: I do have the pictures available from the Kuryakyn installation instructions. Problem with those pics is simple...they're too small to see details.
« Last Edit: June 19, 2025, 06:15:25 PM by John Schmidt » Logged
RP#62
Gilbert, AZ
« Reply #1 on: June 20, 2025, 07:34:57 AM »
How about this angle?
RP
« Reply #2 on: June 20, 2025, 08:02:59 AM »
That's a great shot, thanks loads. I can tell for certain from the picture I won't need the upper vertical piece due to interference with the reverse linkage. The bottom horizontal piece does present a problem since that does interfere somewhat, haven't figured it out yet.
Again, thanks for the picture.  cooldude
RP#62
Gilbert, AZ
« Reply #3 on: June 21, 2025, 08:19:58 AM »
Glad to help John.  Good luck with your project.
RP
