February 11, 2026, 05:35:42 AM *
Author Topic: Fuel drip when choke is on?  (Read 2636 times)
High Desert
« on: June 23, 2025, 09:55:58 AM »
I have a fuel leak sometimes.  It is under the tank.  It only happens when it's running.  Now I think it only happens when the choke is on.  Is there a reason that fuel would drip around the fuel line or rail when the choke is (way) on?  (I cannot see exactly where the drip is occurring.)
« Reply #1 on: June 23, 2025, 10:44:18 AM »
The running engine is because the petcock requires a vacuum to flow. So the leak is after the petcock. I have not heard of a leak with a full choke.
WintrSol
Florissant, MO
« Reply #2 on: June 23, 2025, 01:35:27 PM »
I've never heard of it, but it looks possible. The 'choke', or enrichment valves open a bypass from the pilot/idle mixture jets into the carb outlet, so is directly exposed to fuel, and slides in and out when used. All it would take is a failing seal on the moving part.
Pluggy
NC
« Reply #3 on: June 23, 2025, 06:41:35 PM »
With the tank on, it is hard to find the source of a fuel leak.  Gotta take the tank off.  Mini tanks like this one allow us to see where the leak originates.  We can safely run the engine using this if necessary.
https://www.amazon.com/Royal-Vintage-Spare-Auxiliary-Servicing/dp/B018FVLFZY/ref=sr_1_10?crid=19XZ3FD0O8U78&dib=eyJ2IjoiMSJ9.bPatZmRY0_vEOpL7fV9_MlQnNvvcxx0VnWpnHGWq9Z0xGYPuXPeH7xh4RZ3hrcSzVyxUfYFWycg09YvlPglWMW5CWaXk5dGX_2BE5bLxofBwHGZThxmG2Ngv2ykVQ1bNzpqzkKdbPsTDBng1X7dLjAdx2d99tBydlsfqXqYso1Uhe3YISIM_yjIAg32NEqt6mpwWUy3CHRVEag7d7ED2PaRnpxf2Sx0fD-Y-JlKwZOiZIwQG_UsqOr7Gmum0ncrwsvS6vlpmRDMqKULoz1yNyMEv7ZjBDxqGmsMk0__z9Pk.O0mG1SQvPpbQOcVsld4ScZdbb_5zBBOoQK5IXhnbjmA&dib_tag=se&keywords=motorcycle+test+gas+tank&qid=1750728824&sprefix=motorcycle+test+gas+tank%2Caps%2C196&sr=8-10
 (Don't try riding with this)
« Last Edit: June 23, 2025, 06:48:27 PM by Pluggy » Logged
