December 19, 2025, 06:54:28 PM *
Author Topic: OEM (Hondaline) saddlebag rails vs Cheap knockoffs (Ebay) saddlebag rails  (Read 1309 times)
Knights2theEnd
« on: June 28, 2025, 04:15:22 AM »
I found someone selling Hondaline OEM saddlebag rails for $650. From what I see, they look exactly the same as the cheap ebay ones. How can I tell the difference between the two? I can get the cheap ebay ones for $400. Is the $250 increase in price worth it for the OEM Hondaline saddlebag rails?
bill-jr
VRCC # 35094
murfreesboro
« Reply #1 on: June 28, 2025, 05:47:05 PM »
I couldnt tell the difference been happy with my knockoffs for many years
99' Black tourer
flsix
« Reply #2 on: June 29, 2025, 04:32:49 AM »
Apply a good wax before you install either and it will help keep the eventual rust at bay.
2013 F6B
           ESCHEW OBFUSCATION
Knights2theEnd
« Reply #3 on: June 29, 2025, 03:59:39 PM »
So there is no way of knowing the difference because they are exactly the same? Same diameter, no markings, same everything? So the person selling the hondaline OEM saddlebag rails for $650 could very well be selling $400 ebay ones?
« Reply #4 on: June 29, 2025, 07:23:25 PM »
It is pretty well as you say.  A few of the aftermarket rails don't fit well at the back but they can be made to work.  You really can't tell until you try them.
« Reply #5 on: June 30, 2025, 10:18:52 AM »
The OEM rails have small white teflon plugs in small holes on the upper shock mounts.  The aftermarket ones do not.  That is the only way to tell if I remember correctly.
I have an OEM set that are scratched on the bottom side where you cannot see it unless you are laying down under the bike.
Hay  Cool
« Reply #6 on: June 30, 2025, 01:23:39 PM »
Mine too, on the side I took a bit of a slide on (saved the paint and bag though).  And the saddlebag mounts on that side are a bit sprung as a result too.  Easy to get off, and a PITA to get back on.  It was a long time after the slide that I first pulled that bag off and I was wondering why I was having so much trouble getting it back on.  Then I remembered.   crazy2
