February 11, 2026, 05:35:43 AM *
Author Topic: Source for the Allen Head Brake Pin Plugs  (Read 3990 times)
mello dude
Dayton Ohio
« on: June 29, 2025, 08:41:19 AM »
I seem to remember a thread on this, but search is ridiculous...
What's a supplier for Allen Head pin plugs.
I just got reminded I want them, I had to get out the hand impact wrench for one on a job.
h13man
Indiana NW Central Flatlands
« Reply #1 on: June 29, 2025, 09:56:20 AM »
All the years of fitment both front and rear $4.88 on the 22' 125CRF.
https://www.partzilla.com/product/honda/45203-MG3-016?ref=abdc63dae220f61830335c9d1aa13eeee76bc9ec
mello dude
Dayton Ohio
« Reply #2 on: June 29, 2025, 11:32:03 AM »
That's OEM... not looking for those...I forget who posted it, but had the same with an allen head instead of the flat screw driver type.
Pluggy
NC
« Reply #3 on: June 29, 2025, 12:14:45 PM »
Look for M10 x 1.0  x 8mm flat point grub screw.   Multiple sources are available.  Some of the suppliers had minimum orders and expensive shipping.  Mine came from an eBay seller.
mello dude
Dayton Ohio
« Reply #4 on: June 29, 2025, 02:48:32 PM »
Link to ebay doesn't find the product.
Pluggy
NC
« Reply #5 on: June 29, 2025, 03:15:43 PM »
That link will open using the eBay app.  I removed it. Try this
https://www.ebay.com/itm/134720391589?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=mhwwyykgqjc&sssrc=4429486&ssuid=gBSC4qtRQRe&stype=1&var=434224761759&widget_ver=artemis&media=COPY
« Last Edit: June 29, 2025, 03:46:54 PM by Pluggy » Logged
« Reply #6 on: June 29, 2025, 05:10:27 PM »
yes better prices can be found, than I posted
https://www.valkyrieforum.com/bbs/index.php/topic,125567.0.html
ridingron
Orlando
« Reply #7 on: June 30, 2025, 01:30:18 PM »
Have you tried a local hardware store like Ace?
Any type screw will do. I've used a short hex head bolt before. I see it as a "plug" to keep dirt out and to lock the caliper pin so it can't back out.
mello dude
Dayton Ohio
« Reply #8 on: June 30, 2025, 08:21:21 PM »
Almost pulled the trigger and clicked on buy now, but with shipping came out to 6ish bucks apiece....
Nnnnooo! I'll live with the OEM.
Tried Lowes, no go, try ACE next....
-mike-
Germany
« Reply #9 on: June 30, 2025, 11:07:19 PM »
That's the instructions I followed when I had to replace mine:
https://web.archive.org/web/20190702140524/http://valkyrienorway.com/Techpinplug.html
I took stainless bolts and polished them to chrome like finish.
« Last Edit: June 30, 2025, 11:14:00 PM by -mike- » Logged
mello dude
Dayton Ohio
« Reply #10 on: July 01, 2025, 12:49:30 PM »
Good tip... follows the .. If you cant find waht you want, make your own....
I am totally on board with that!  cooldude
SCain
Rio Rancho, NM
« Reply #11 on: July 02, 2025, 05:31:33 AM »
McMaster Carr
Thread Size   Drive
Size   Max. Pressure   Material   Specifications Met       Each
Metric Male
M10 × 1 mm   5 mm   5,600 psi @ 72° F   Zinc Plated Steel   DIN 7631, ISO 9974   4936K925   $2.77
Steve
h13man
« Reply #12 on: July 02, 2025, 09:50:27 AM »
I'd say if you use anti seize it shouldn't matter what style of head configuration when loosening again. Its definitely an area of great corrosion and filth.
