May 12, 2026, 09:28:43 PM *
Author Topic: How to tell if the heads are off a 97???  (Read 4627 times)
CoreyP
Bluffton, SC
« on: July 17, 2025, 02:43:09 PM »
A guy has a set of heads for sale that he says are from a 1997 Valkyrie. How would you tell what year they came from? The heads are interchangeable on Valkyries correct? A 1997 head would have the more horse power camshafts than a 2001 Valkyrie, correct. See where I'm going with this? Seems like a pick up some horsepower for fairly cheap.
« Reply #1 on: July 17, 2025, 03:17:56 PM »
From what I have found all GL1500 heads all yrs are the same.
camshafts are stamped either R1 HP or R2 emissions.  Not all '97s will have the R1 cams. most Dyno testing has shown a 10HP difference. few more better MPGs with the R1 cams also.
see cams here  https://www.valkyrieforum.com/bbs/index.php/topic,54105.0.html
« Last Edit: July 17, 2025, 03:24:40 PM by 98valk » Logged
h13man
Indiana NW Central Flatlands
« Reply #2 on: July 17, 2025, 04:43:02 PM »
From what I've read here, the ICU is different thus the hp. difference. Highly sought after.
« Reply #3 on: July 17, 2025, 06:55:30 PM »
Nope. only I/S ICM has faster advance to about 3k rpms, then to redline same curves.
CoreyP
Bluffton, SC
« Reply #4 on: July 17, 2025, 08:37:05 PM »
He doesn't know but the sell er will look for R1 or R2. Doesn't look like you can see it without take the cam out of the head.
https://www.facebook.com/marketplace/item/1054516689827984/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Ab9c8f9ff-b140-4f46-93a8-5647c704c35f
« Reply #5 on: July 18, 2025, 03:55:36 AM »
cams do not need to be removed, just rotated to see. indication is near the one end
see cams here
« Last Edit: July 18, 2025, 03:57:08 AM by 98valk » Logged
h13man
« Reply #6 on: July 18, 2025, 06:51:23 AM »
Thank you for the reminder. Duh.  cooldude
97' and 99' cams are the same part number for non CA models. I see the piston is different part number from 97 thus suggesting a compression difference but...
« Reply #7 on: July 18, 2025, 07:32:02 AM »
nope on compression, per service manual all yrs all GL1500 engines have same compression, since '88.
many manufacturers change the part numbers after the 1st or 2nd yr of production of the vehicle.
HP numbers of these engines are strictly due to OEM camshafts.
The I/S slide springs will increase mpg. They lean out the needle range which is too rich. too rich lowers HP, so there is a small HP increase with the I/S springs, mostly they will provide better engine response over a wider ambient temp range.
I/S has the better fuel tank, triple clamps and rear shocks. std/tourer are better forks than the I/S.
Dirty Dave
Montreal, Canada
« Reply #8 on: August 12, 2025, 02:43:39 PM »
I've had the I/S slide springs and ICM in my 97 std for 20 years so just for fun
I swapped back the ICM to see how it feels. (Yes, retired & bored)
I remember liking the change to I/S parts very much back them.
It's weird being the same age as old people
Dirty Dave
Montreal, Canada
« Reply #9 on: August 13, 2025, 09:37:33 AM »
Not worth swapping back to the I/S ICM.
Really didn't notice any difference.
I suppose the major change comes from the I/S slide springs.
I also did the ECT mod years ago.
