December 19, 2025, 08:33:42 PM
Rear Shock Setting
Topic: Rear Shock Setting (Read 1216 times)
dan7uk
Louisville, Kentucky
Rear Shock Setting
July 20, 2025, 02:27:10 PM »
Took my 99 interstate out today for a run and it seem ride was a little harsh. Got back home and I notice the rear shocks were set at 4. I run my air pressure around 36 lbs., both tires. Just curious, what's your rear shock set at?
Last Edit: July 20, 2025, 02:30:17 PM by dan7uk
Re: Rear Shock Setting
July 20, 2025, 02:50:06 PM »
Single rider on an Interstate #3 should be enough. Two/up I can see #4. I recommend you up the tire pressure to 40 on both or even 42 rear 40 front. It will save your tires from cupping and other premature wear.
July 20, 2025, 03:03:18 PM »
Quote from: dan7uk on July 20, 2025, 02:27:10 PM
follow what Chris stated. check the upper shock bushings, if bad they will provide a harsh ride.
only use Redeye.
https://redeye.ecrater.com/p/18385698/rear-shock-bushing-kit-ver-2
July 20, 2025, 10:58:27 PM »
Hondas OEM bushings have been updated to polyurethane like Red Eye.
=> InZane XXV
