May 12, 2026, 09:29:03 PM
Replace clutch hydraulic line
Topic: Replace clutch hydraulic line (Read 2139 times)
Fazer
August 09, 2025, 08:47:00 AM »
I am trying to replace my brake and clutch lines with braided steel. I can handle the brakes but cannot see how the clutch line is routed. I see where it connects to the slave but cannot see the line above the engine. Is it necessary to remove the fuel tank to get to it? I just filled up so if that’s the case I will hold off until I run the fuel out.
Thanks.
Nothing in moderation...
Re: Replace clutch hydraulic line
August 09, 2025, 09:31:56 AM »
Quote from: Fazer on August 09, 2025, 08:47:00 AM
Thanks.
yep its routed and attached to the upper frame. u might be able to lift the tank and tilt it to the right. I do the tilt procedure to change out the air filter. when I did mine and the was tank off.
Fazer
August 09, 2025, 09:36:04 AM »
Thanks. I took the seat off and can see where the rubber hose meets the rigid line and cam to that conclusion. Probably ready for the air filter as well.
mello dude
Dayton Ohio
August 09, 2025, 10:30:13 AM »
Photos from a horn relay job, but look at the hose marked with a dab of blue paint.
The line swings by the airbox. I replaced mine a few years back.
Have you already purchased a new line?
If we can coordinate schedules, I may be able to come down for some help...
August 09, 2025, 01:33:50 PM »
Quote from: Fazer on August 09, 2025, 09:36:04 AM
unless u ride dirt roads and construction sites the air filter lasts longer than 12k miles. I tested mine over 24k miles and it had same restriction as a new one. many vehicle manufacturers over 20 yrs ago went to a 12k change out to sell product, like the 3k oil change.
YMMV
Fazer
August 11, 2025, 11:54:34 AM »
98 Valk--last time mine was changed was in March 2019, 29,000 miles ago by Attic Rat when he did his magic. I think it's due.
Reply #6 on:
August 11, 2025, 01:12:38 PM »
Quote from: Fazer on August 11, 2025, 11:54:34 AM
sounds good.
remove the metal screen for some added air flow and some extra intake roar.
