Tx Bohemian
« on: February 22, 2010, 01:44:15 PM » |
Does anyone have, or have used a Drill Doctor? (or similar device) I probably have over three sets of drill bits and probably ½ set that is sharp enough to use.
Do these things work?
On their website there’s 4 models, which would be the best?
Remember, if you are on a bike and wreck with a car no matter how "in the right" you are you are going to lose. RIDE LIKE EVERBODY IS OUT TO GET YOU!! Al
3W-lonerider
« Reply #1 on: February 22, 2010, 02:01:35 PM » |
yes i have a drill doctor..and yes they work great.. i have one of the original models that came out years ago.
gregc
« Reply #2 on: February 22, 2010, 02:21:16 PM » |
Yes they work great, I have the standard model that does up to 1/2 inch drill bits. I will keep them brand new sharp, till they are just a little stub left. Haven't bought a new drill bit in years, well worth the price, which I think was around 79 dollars 5 years ago.
BudMan
"Two's in."
Tecumseh OK
« Reply #3 on: February 22, 2010, 02:44:11 PM » |
They do a great job on a drill that is just dull. The new edge will hold up just fine as long as the drill has never been overheated to the point of discoloration during use.
Buddy Tecumseh OK MOOT# 263 VRCC # 30158 1948 EL Harley 2013 F6B Delux "I rarely end up where I was intending to go, but often I end up somewhere that I needed to be," Dirk Gently; Holistic Detective
Doc Moose
VRCC#506 - VRCCDS#0002 - BOTS
« Reply #4 on: February 22, 2010, 02:54:05 PM » |
Sounds like a product name I could love......
 Retired OF - Everyday is Saturday! GW/Roadsmith Trike
big turkey
« Reply #5 on: February 22, 2010, 03:10:39 PM » |
A drill Gauge and a little practice at the grinding wheel is what I use , but then again I am a Machinist.
But about anybody can do it.
You can buy these at the hardware for about three dollars.
When you get the hang of it you will have a sense of accomplisment .
This is assuming you have a bench grinder.
Wear your safety glasses.
AL
sugerbear
« Reply #6 on: February 22, 2010, 06:28:47 PM » |
Ratdog
« Reply #7 on: February 22, 2010, 10:13:31 PM » |
Sounds like a product name I could love......  It's right up your alley Jim... right up your alley.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
« Reply #8 on: February 22, 2010, 11:18:15 PM » |
Yeah I've used one for years. One caveat - Be sure to carefully sand off any burr you leave on the edge of the new tip - it will make your hole slightly larger. Only if you need to be precise on the hole size. Also - if I'm sharpening a broken bit, or one I've cut down to be a shorty for clearance reasons, I'll first rough out the shape of the tip on a wet grinder, to save wearing down the diamond wheel in the DD. (This is for larger bits, not needed so much for 1/4" and smaller.) Also, if you are going to cut off a bit and then sharpen it, don't get it hot or you'll ruin the temper. I'll cut it off while cooling it with a water spray.
Jess Tolbirt
« Reply #9 on: February 23, 2010, 03:19:30 AM » |
i use my DD a lot,,, has saved me hundreds of dollars in the past 10 years or so....
Valkyrie member # 23084 Started out on old forum on day one but lost my member number.
