May 12, 2026, 08:31:48 PM *
Author Topic: What oil are you using in your Valkyrie? ---- Survey only please  (Read 13544 times)
mello dude
Dayton Ohio
« on: August 24, 2025, 12:32:54 PM »
Dont wanna start a usual technical, why and how mines better than yours discussion on oils. But just interested and for curiousity of what guys are using. Its just to score it, nothing else.
If you want to add a product let me know. I'll add as we go, plz come back and click your selection.
Thanks all!  cooldude
« Last Edit: August 24, 2025, 03:00:23 PM by mello dude » Logged
rug_burn
Brea, CA
« Reply #1 on: August 24, 2025, 12:42:41 PM »
Mobil One 10-40 extended mileage, Walmart $25 for 5 qt...
...insert hip saying here..
« Reply #2 on: August 24, 2025, 12:52:29 PM »
Mobile One V-Twin 20-50
« Reply #3 on: August 24, 2025, 04:30:37 PM »
any Diesel oil that meets Ford specification WSS-M2C171-F1, which requires zinc and phosphorus levels above 1000ppm. many newer oils have less, even JASO requires less than 1000ppm.
engine was designed pre-'88 and first built in '87 requiring SE or SF oil.  SF-SL 1000 - 1400 zinc
SC-SE 1000 - 1200 zinc
https://bobistheoilguy.com/forums/threads/what-zinc-limits-levels-for-sm-sj-sh-sg-sf-etc.73571/
http://www.valkyrieforum.com/bbs/index.php/topic,65911.0.html
 why only a heavy duty diesel oil should be used
« on: March 25, 2014, 07:32:47 AM »
   Reply with quoteQuote Modify messageModify Remove messageRemove
http://www.lngpublishing.com/LNGmagazine/index.cfm
this months issue
http://viewer.zmags.com/publication/e9f4b3fd#/e9f4b3fd/1
see article  Two-wheelers love oil too!
JASO spec'd motorcycle oil are basically the same specs as heavy-duty diesel oil standards.
JASO does not test oils, manufactures pay a fee to JASO and state their oil meets the specs.
see article, another grade for the heavy-duty upgrade?
« Last Edit: August 30, 2025, 05:45:21 PM by 98valk » Logged
mello dude
Dayton Ohio
« Reply #4 on: August 25, 2025, 12:03:56 PM »
This is going good!  Keep 'em coming.  cooldude
« Reply #5 on: August 25, 2025, 12:40:26 PM »
I put Amsoil bike 10/40 in my bikes once and it was the quietest they ever ran (by far).
But the cost is ridiculous, and I've had no trouble with other good synthetic (Mobile 1, which isn't cheap either, but not ridiculous. )
holly
« Reply #6 on: August 25, 2025, 12:56:40 PM »
   I have used a few different ones including auto and motorcycle oil. I have not noticed any big difference in any of them. I am currently using Castrol Power 1 10w40. my plan is to stick with it, or maybe use it in the 10w50 formula.
Ghostrdr
Collinsville, Illinois
« Reply #7 on: August 25, 2025, 01:43:22 PM »
Mobil 1 15/50. 107000 and counting.
Disco
Republic of Texas
« Reply #8 on: August 25, 2025, 01:48:54 PM »
T4 almost all the time.  Mobil 1 a few times.  Purolator PB or PBL 14610 every time.
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
mello dude
Dayton Ohio
« Reply #9 on: August 25, 2025, 02:42:14 PM »
As mentioned before, I will add more as guys post up oils not on the list....and also after adding to the list, plz come back and click your
choice.
Kinda interesting as we go... Cool
« Last Edit: August 25, 2025, 02:44:09 PM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #10 on: August 25, 2025, 06:36:52 PM »
Hi -- Is that Rotella T4 and what grade?
thxz
h13man
Indiana NW Central Flatlands
« Reply #11 on: August 26, 2025, 07:06:04 AM »
Used Rotella T6 until formula change. Next was Valvoline 4T dino and it brokedown @ 3,000 mi. Mobil1 10w-40 with 7500 mi. change from here on out as the 5,000 mi. change was still very clear looking.
Mobil1 Extended range, isn't it oil for cars? Mobil1 for MC's is about $44 for 4 qts. not $28 bucks for 5 qts. like for our AWD Suzuki car with almost 180,000 mi. and still going strong. I use dino in the GMC as came to me almost 50,000 mi. and no history of oil changes etc. It was a commercial vehicle so I'm sure dino was used. Used T6 for many a year but Chubby didn't like it whatsoever. Noisier tranny noise and not as smooth shifting. Changed out within 100 mi.
Disco
Republic of Texas
« Reply #12 on: August 26, 2025, 07:59:27 AM »
thxz
Yes, 15w-40.   cooldude
I change oil at 5,000 miles and service the final drive at 10,000 miles.
78 CB550K, 07 Helix
71 MT50 Trailhopper
Draeger
Nanaimo, British Columbia
« Reply #13 on: August 26, 2025, 09:09:07 AM »
Motul SV 300 10-40 Synth
If you are distressed by anything external, the pain is not due to the thing itself, but to your opinion of it; and this you have the power to revoke at any moment. ~ Marcus Aurelius
Nightflight99
DFW, Texas
« Reply #14 on: August 26, 2025, 10:43:41 PM »
Motul 7100 10W-40
2000 Honda Valkyrie Interstate
2001 Honda Valkyrie Standard
2010 Triumph Street Triple
2013 Suzuki DR650
2017 Triumph Rocket III Roadster
2016 KTM 690 Enduro R
2021 Triumph Rocket 3 GT
Lindsay6669
Brisbane Australia
« Reply #15 on: August 30, 2025, 02:15:38 AM »
1800 valkyrie  penrite 5w30
F6Dave
« Reply #16 on: August 30, 2025, 08:36:18 AM »
I'm surprised at the variety of motor oils we use. If you look at the shelves in Walmart or an auto parts store just a few brands dominate, so I didn't think we'd be using so many.
I used to use Mobil 1 15W-50 automotive in both Valkyries but recently switched to Rotella T4 15W-40 conventional oil. It was just out of curiosity as the difference in price per quart is only about a buck. Used oil analysis showed similar wear metal levels for both so I don't know if I'll switch back or not. I'm still using the Mobil 1 in my GL1800 (F6B).
« Reply #17 on: September 03, 2025, 05:32:02 AM »
someone mentioned rotella T6 5w-40 the formula components of the oil said changed so no longer using it.  How, when,  or what did they change since been using that ever since Amsoil got so expensive over a decade ago.
h13man
« Reply #18 on: September 03, 2025, 06:55:03 AM »
As I'm the only one here thats posted that has had an issue with post 17' T6 formula. Used it w/o issue in the 00' ZR7 and the 06' VT1100 for 6 yrs. A fellow HSN member had issue in his ST1300 also. Now the dino Rotella might work better but I already committed to using synthetic thus Mobil1 put everything back in order after a slight oil quest with Valvoline dino.  Wink
mello dude
Dayton Ohio
« Reply #19 on: September 03, 2025, 09:13:36 AM »
Kinda interested in the T6 formula change thing... was that 5W-40 only? or 15W-40 too?
And when was it?
This survey is going really good! Very cool!  cooldude
Most listed as a zero its really a 1.....from someone that posted in the thread...
« Last Edit: September 03, 2025, 12:52:04 PM by mello dude » Logged
Disco
Republic of Texas
« Reply #20 on: September 03, 2025, 05:12:18 PM »
T4 is semi-synthetic.  It's a blend of synthetic and conventional.   cooldude
78 CB550K, 07 Helix
71 MT50 Trailhopper
h13man
« Reply #21 on: September 04, 2025, 04:47:05 AM »
And when was it?
EPA changed the rules on all diesel oil's in 2017'. Ford raised quite stink about it.
« Reply #22 on: September 04, 2025, 05:42:52 AM »
And when was it?
that's why I've been posting about that all of this time and why only use an oil that meets the Ford spec. it seems too many people have me blocked and/or ignore my posts. post the ford spec in this thread
RonA
Saskatchewan
« Reply #23 on: September 04, 2025, 02:25:42 PM »
Pretty sure that T4 is conventional, T5 is a con. syn. blend, and T6 is a full syn.
RonA
Saskatchewan
« Reply #24 on: September 05, 2025, 08:00:56 AM »
[][/img]
F6Dave
« Reply #25 on: September 05, 2025, 01:23:21 PM »
It was. I looked it up and in 2021 Shell changed the formula and now it's a blend.
F6Dave
« Reply #26 on: September 05, 2025, 01:35:58 PM »
As i mentioned earlier I recently switched from Mobil 1 15W-50 to Rotella T4 15W-40. I had the oil analyzed for both. Wear metals were the same, but they use different anti-wear packages. Mobil 1 has more moly and magnesium while Rotella has more boron and calcium. In my Valk it made no difference.
mello dude
Dayton Ohio
« Reply #27 on: September 06, 2025, 05:56:18 PM »
I hate going here.... but on T6 .... what is the change?
Per survey, it doesnt seem to concern many of us.
Joe333x
Boston
« Reply #28 on: September 07, 2025, 09:31:18 AM »
Yeah idk, I've been using T6 in my motorcycles for over 20 years now and this is the only site I have seen someone say something about a change to it that effects motorcycles? The bottle has a picture of a motorcycle on it and it still says JASO on the back so unless I see some type of concrete evidence that I shouldn't use it, I'll keep using it. It's in both of my bikes right now.
« Reply #29 on: September 07, 2025, 09:48:30 AM »
T6 5w40 does not does meet the Ford spec. they fixed their website.
the T6 15w40 does meet the Ford spec and can be used.
https://www.shell.us/business/fuels-and-lubricants/lubricants-for-business/products/shell-rotella-heavy-duty-engine-oils-for-fleets/shell-rotella-t6-full-synthetic-heavy-duty-engine-oil.html
« Last Edit: November 01, 2025, 03:01:02 PM by 98valk » Logged
John97
« Reply #30 on: September 07, 2025, 09:39:49 PM »
Looks like I’m 50% of the riders using GN4 10w-40 and I use the Honda filter too. Worked at the dealership still have nice discount. Same thing for my Magna.
mello dude
Dayton Ohio
« Reply #31 on: September 18, 2025, 11:19:36 AM »
Bumping this... want to get as many votes as possible...
« Reply #32 on: September 18, 2025, 12:50:37 PM »
over the yrs in used oil analysis comparisons honda oil made by who knows who, never tested well. Why I always state the better oils are good for at least a 10k oil change.  todays oils are so much better than the oils specified in '88.
mello dude
Dayton Ohio
« Reply #33 on: October 04, 2025, 10:41:57 AM »
51 votes is pretty good, but bumping one last time....
Survey turned out very good. Somewhat turned out like I expected with Rotella 5W/15W - 40 and
Moble 1 4T, and Amsoil the top 4.
 Thanks to all that replied.  cooldude
 Smiley
Jersey mike
Brick,NJ
« Reply #34 on: October 20, 2025, 05:19:52 AM »
Saturday I changed the oil in the bike, been using Mobile 1 (full syn) for a long time and I used my last 4 quarts ffrom the case I had. When I went to the Auto Zone after to dump my oil, I see that they no longer stock Mobile 1 10/40 (full syn) in either the regular or high mileage but they do have in stock what they call Mobile 1 Racing 4T 10/40 full syn. I did buy 4 quarts of that to have something on hand.
I don’t like shopping at our Walmart but after a quick search it seems Walmart does still carry the original M1 and High Mileage both full syn.
Anyone using the M1 10/40 Racing 4T?
« Reply #35 on: October 20, 2025, 05:55:06 AM »
Be careful with that High Mileage blend.  I think that it has friction modifiers in it that will make our clutches slip.  Look at the circle on the back of the bottle and if the bottom of the circle is blank, you are good to go.  If not, they put the friction modifier info in the bottom part.
UPDATE:  I just looked at the High Mileage 10-40w and the bottom of the circle is empty, so that should be good to go.
https://www.amazon.com/Mobil-High-Mileage-10W-40-5QT/dp/B07GLGY2RY/ref=sr_1_1?crid=3IYP7SI4YCVHB&dib=eyJ2IjoiMSJ9.2llnrveMQbhiXU-ubxLVBJdZ7TbXQkjWZbS-8XCpQVouMyBRZ_CC3lUvqfR-gf8u3-0-muysnKpq28XQVDhQghHAEH3Tp56pKJckNm81w4qa3m2qs6zt7eIR-O4ZqLXhv4lHsNjSM94K_Jgu4uf8uDjb1NrVJJ7QwX7Y9KegPdVnXERW3-Xo9rX0U_4aBZpwJGNejuCchcr6R4zpFIVMb5UjtVwy1Qf2r9zkrOzSXDOwCt7LdchDtx4f47TrUwqCEAukEXM74pH0OoHATaVzfuYyRrdoCQbui56BcvKTZdo.WL2VKN8swJkx4b_CtWz6jtkRFBg5mJEEUqc-gyN9vEc&dib_tag=se&keywords=high%2Bmileage%2Bmobil%2Bone%2Boil%2B10w-40&qid=1760965122&sprefix=high%2Bmileage%2Bmobil%2Bone%2Boil%2B10w-40%2Caps%2C239&sr=8-1&th=1
Just my $.01875.
Hay  Cool
« Last Edit: October 20, 2025, 06:01:03 AM by HayHauler » Logged
mello dude
Dayton Ohio
« Reply #36 on: October 20, 2025, 11:50:50 AM »
That has been my goto oil for motorcycles for street bikes for years, nice oil....The Valkyrie likes it fine.
We have 7 votes on it here. I hate Walmart, but it always has the best price for it.
Jersey mike
Brick,NJ
« Reply #37 on: October 20, 2025, 12:54:02 PM »
How far do you go on oil changes. I usually do 5k with an OEM filter.
mello dude
Dayton Ohio
« Reply #38 on: October 20, 2025, 06:28:36 PM »
I usually go around 4K ish, sometimes it could be 3.5k depending on where in the season it is,  with Bosch filters, 3300 or 3323 I buy on Amazon....
Probably overzealous... but I havent met a motorcyclist guy that wasnt in some respects.
« Last Edit: October 23, 2025, 09:45:56 PM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #39 on: November 01, 2025, 02:08:07 PM »
The lack of a Ford spec turns out to be hooey...
