February 11, 2026, 03:37:55 AM *
Author Topic: carb synch springs  (Read 1314 times)
ap73
« on: September 13, 2025, 05:41:21 PM »
I did my first carb separation and everything went great until I bolted them back together and I may have crushed a carb synch spring.  I can't find a part number anywhere for them.  They measure 10.2 long and 5.8 O.D.  That's an odd size and doesn't really match up to a metric or imperial size.  Anyone got a part number for them or could I just use a generic 10x5 spring from amazon?
« Reply #1 on: September 13, 2025, 10:01:27 PM »
Are you talking about item #6 on the carb component exploded view? The screw and associated parts come as a set which includes the spring.
ap73
« Reply #2 on: September 14, 2025, 04:26:10 AM »
I think #6 is the bigger spring that goes between the butterfly cams?  Or do yo mean it comes with that spring?  Sorry I don't have a picture the on board picture hosting keeps giving me an error when I try to upload.  This is the little spring that holds tension on the synch screws.
You can see one in the the opening picture in this video link
https://www.youtube.com/watch?v=7rtNABYbpmk
Its just to the left of the intake port and between the carbs.
I wound up ordering
https://www.amazon.com/dp/B0C33CBKFY?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
they seems to be the right size and wire diameter.
