November 04, 2025, 08:40:00 AM *
Author Topic: An Extremely Large Comet That Was Just Discovered  (Read 858 times)
« on: September 17, 2025, 06:58:57 AM »
The complete headline from the link below:
In Early October, Earth Will Pass Through the Orbital Debris Stream of an Extremely Large Comet That Was Just Discovered
Some text from link below:
There’s a new, fairly bright comet in the sky, discovered less than a week ago, on Friday, September 12, 2025.
Scientists have just discovered another giant space rock that is rapidly heading in our direction.  They think that it will fly past us at a distance of just 0.26 astronomical units, and if they are correct about that it won’t hit us.  But we are being warned that Earth will pass through the orbital debris stream of this extremely large comet, and that could result in a significant meteor storm.  This comet was first identified less than a week ago, and so any projections that have been made so far could change.  It is officially being called “C/2025 R2 (SWAN)”, and it is already “bright enough to detect using binoculars”…
At this moment, it is being projected that C/2025 R2 (SWAN) will come within just 0.26 AU of our planet in late October, but we will actually cross the comet’s orbital debris stream in early October…
Between October 18-21, 2025, Comet SWAN will be only 0.26 astronomical units AU from our planet. If it does not fall apart between now and then, it could become a beautiful target for photographers and backyard astronomers. Another date of interest is Oct. 4-6 when Earth may cross the comet’s debris stream. If so, we could have a meteor shower. Stay tuned for updates.
https://discernreport.com/in-early-october-earth-will-pass-through-the-orbital-debris-stream-of-an-extremely-large-comet-that-was-just-discovered/
Just for the record an "AU  or astronomical unit, is a unit of length defined as the average distance between the Earth and the Sun, approximately 149.6 million kilometers (about 93 million miles). It is commonly used in astronomy to measure distances within the Solar System."
So, 0.26 * 93,000,000 is about 24,180,000 miles.  Pretty close pass.
I think the reason we will pass through the comets orbital stream first is because the steam is pushed away from the sun, by solar radiation.
Or from Wikipedia: "solar radiation causes the volatile materials within the comet to vaporize and stream out of the comet nucleus, carrying dust away with them. Blown by the solar wind, these materials typically form two separate tails that extend outwards from the comet's orbit: the dust tail, composed of comet dust, and the gas or ion tail, composed of ionized gases"
« Reply #1 on: September 17, 2025, 01:03:10 PM »
Well, I was excited when I first read about the comet.  The webpage I found was really "hot" over the discovery.
However, in further reading, the comet is not expected to get bright enough to be visible to the naked eye.  But should be visible with binoculars.  Right now, the comet is in the west after sunset, not far from the planet Mars (as viewed in the sky). The comet appears among the background stars of the constellation Virgo.
Actually today (or tonight) Comet SWAN R2 will appear low in the WSW  be between Mars and the star Spica just after dark.
It will continue in this area and get higher and higher into the sky between now and October 2.  However, it will still probably not be "naked eye".visible.  But that could change.
« Last Edit: September 18, 2025, 09:50:49 AM by carolinarider09 » Logged
LadyDraco
TISE
« Reply #2 on: September 17, 2025, 04:56:57 PM »
I was reading  about that the  other day as well... coolsmiley
This  is  the  way
h13man
Indiana NW Central Flatlands
« Reply #3 on: September 18, 2025, 08:45:56 AM »
It seems all the solar activity this year, we're always under the clouds or I forget. Grin No light pollution on the prairie.
« Reply #4 on: September 18, 2025, 01:38:33 PM »
Now if we could just get Elon to figure out how to harness all of hat energy……
