February 11, 2026, 03:37:53 AM *
Author Topic: Bike running rough  (Read 2297 times)
DragonRdr
Gardner, MA
« on: September 20, 2025, 06:40:31 AM »
This post isn't about my Valkyrie, it's about my 94 Gold Wing, but they share a lot of the same problems and I know some of you may have experience with Gold Wings.
I was out riding the Gold Wing yesterday and it was running great. I went over a bump at about 5 mph (enough of a bump that it shifted all the stuff in the trunk) and the bike started running rough and died when I stopped Cry. I was able to get it started again but I had to leave the choke on or the engine would shut off. I decided to ride it home since I was close and try to figure out what's going on? I thought maybe a plug wire came loose, but they're on pretty tight. Then I started thinking maybe the bump knocked a vacuum line loose or maybe I knocked something loose that's blocking the fuel in one of the carbs? Anyway the local Honda dealer doesn't work on GL1500s anymore. Anyway any ideas or suggestions would be appreciated. Thanks in advance.
2000 Valkyrie Interstate
1994 Goldwing Interstate
« Reply #1 on: September 20, 2025, 08:17:14 AM »
If you have plenty of fuel I think I agree with you, my first thought is electrical. Check battery connections and ground strap and all fuses. After that I dunno  Undecided
DragonRdr
Gardner, MA
« Reply #2 on: September 20, 2025, 11:04:45 AM »
Thanks Chris. I was able to start it this morning and it's idling at about 500 rpm after I shut off the choke and still running rough, but it's not dying now. The exhaust on the right side sounds funny like it's not running on all cylinders, so maybe it is a plug wire. I'll let you know how things go. Wish me luck.
« Reply #3 on: September 21, 2025, 07:09:17 AM »
Get a thermometer and check the exhaust headers after running it.  This will help to nail down which cylinder(s) are the issue.
It's a start, then you can get into why.
Timbo1
Tulsa, Ok.
« Reply #4 on: September 21, 2025, 08:52:17 AM »
I don't know much about GW's but in my mind if the choke helps to keep it running that makes me think fuel issue.  The choke doesn't alter the electric system it affects the fuel / air.  IDK if the GW has an enricher or actual choke but regardless they both alter the Air/Fuel mixture by increasing fuel and decreasing air.   If I recall the GW has only 2 carbs one for each bank of cylinders that disperse fuel through a intake manifold.  If only one side seems to not be running correctly I'd suspect that side carb.  Maybe stuck float needle, maybe debri in the jets?  I'd try lightly tapping on the float bowl of the offending carb and add a dose of fuel cleaner to the tank.  I think the GW also has a fuel pump & inline filter, I'd make sure they are clean and pumping adequately.  Of course make sure all vacuum lines are good and connected.
DragonRdr
Gardner, MA
« Reply #5 on: September 22, 2025, 03:31:29 AM »
Thanks everyone for the tips. I've narrowed it down to the right side.  After I check the carb, vacuum lines and fuel filter I'm going to get some Berryman's B-12 and run it through the fuel system. I'm also wondering if it could be the exhaust that's blocked up? The right side is definitely cooler than the left and the exhaust pressure seems lower? The bike is 31 years old and still has the original exhaust.
Thanks again everyone, I'll keep you posted.
« Reply #6 on: September 22, 2025, 04:18:10 AM »
I've had mice convert exhaust systems into condos.
Worth checking.
Jims99
Ormond Beach Fl.
« Reply #7 on: September 22, 2025, 04:58:47 AM »
There are a few vacuum lines under the carbs (under rubber cover) that dry out and crack. They are a pain to get to, but that could be your problem. I can’t seem to find the diagram I had that showed exactly where. If you don’t find a problem with electrical, I would check them next. Try spraying starting fluid around the vacuum lines and see if rpm changes.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
DragonRdr
Gardner, MA
« Reply #8 on: October 12, 2025, 10:32:57 AM »
I thought I would post an update on my 94 Gold Wing problem. For those of you that have owned a GL1500, you know what a pain it is to take off all the plastic body panels so you can access the carbs. To make a long story short, after checking everything the Honda service manual recommended, it ended up being a bad spark plug or plugs. I ended up changing out all six. Now it's running fine. Since I have everything apart I went ahead and ordered a new fuel and air filter. Once those arrive I'll install them and put everything back together. While I'm waiting I think I'm going to double check all the carb hoses again just to be sure. Thanks for all your suggestions and recommendations.
Cheers
da prez
Wilmot Wi
« Reply #9 on: October 12, 2025, 11:02:26 AM »
  The mufflers are easy to remove. Pull both , start the bike up for a short run. Rev it and shut off. Stand the muffler inlet down and bounce it on a piece of wood. Flip over and repeat. May have to do it a couple times. If there are snuffers in the outlet , they  should be removed.
 I just did one last week. The mufflers hide a lot of debris.
         da prez
rug_burn
Brea, CA
« Reply #10 on: October 14, 2025, 11:20:11 AM »
I had a truck that would quit after going over bumps, and it was due to a bunch of junk at the bottom of the carb bowl which would clog something up for a second.   It came from the fuel pump, the diaphragm or something.
...insert hip saying here..
DragonRdr
Gardner, MA
« Reply #11 on: October 16, 2025, 01:29:10 PM »
My GL1500 is back up and running. It was a combination of things I believe. I put Berryman's B12 in a fresh tank of fuel, changed the fuel and air filter, changed all 6 spark plus and put 1/4 galvanized mesh over the Air Filter box intake (I found a critter nest inside when I checked the air filter). The GL1500 also has a sub air filter that I also changed. It had deteriorated and some of it may have gotten into the carbs as well. I'm hoping for some warmer weather so I can take it for a ride. It's supposed to be in the 60s this weekend. Rug_Burn, I think you may be right about the crap in the carb bowls, hopefully the Berryman's B12 I put in the fuel helps. Thanks everyone for the advice and suggestions.
Cheers cheers
