Slyk Willy
« on: September 29, 2025, 01:06:43 PM » |
I stupidly allowed by I/S to fall over. I was going for a ride, key on, kickstand up, switch to "run", and since it's been a while, battery was so low it wouldn't start. Proceeded to remove myself and not having put the kickstand down, the bike fall on it's side as I escaped. I plugged it into my charger while waiting for SIL to come to the rescue. My SIL assisted me with the bike to get it up-right. I checked the oil to be sure no gas found it's way into the crankcase, and went to fire the old girl up and click, no crank. I put the kickstand up and down a few times thinking the switch may have damaged but also thought about the bank angle switch. Before I start down the path, any other thoughts?
Slyk Willy VRCC # 16194
« Reply #1 on: September 29, 2025, 01:24:00 PM » |
Perhaps you shouldn't have waited for your sister in law.
When the bike fell over it might have tripped the upright switch, but that should've been reset by turning the ignition switch off and on again. Might also check the kill switch.
« Reply #2 on: September 29, 2025, 01:26:18 PM » |
Ordinarily, the tip over switch (bank angle sensor) only requires you to switch the ignition on/off/on to reset (after the bike goes over). Maybe a couple times.
There's a bunch of old threads on here about it. Here's one https://www.valkyrieforum.com/bbs/index.php?topic=126285.0
Slyk Willy
« Reply #3 on: September 29, 2025, 01:47:49 PM » |
Hey, if she could pick it up, I'd let her. LOL, but with three daughters I only have SONs in law. No Sis in Laws either
Thnx for the thoughts on the switch.
« Last Edit: September 29, 2025, 01:50:45 PM by Slyk Willy »
Slyk Willy
« Reply #4 on: September 29, 2025, 01:49:57 PM » |
Haven't thought about the kill switch, I'll check that too. Yeah, I keyed it a number of times. (no joy) Thnx guys for your insight.
Slyk Willy
« Reply #5 on: September 29, 2025, 01:55:54 PM » |
KILL SWITCH!!!! cycled it a few times and fired right up. Thnx for the insight!
« Reply #6 on: September 29, 2025, 02:37:34 PM » |
When you have to manhandle the big heavy bike to lift it up it's easy to hit the kill switch by accident. I've done the same thing a couple times. It doesn't help that I NEVER use the kill switch on purpose. I either use the key or put the kickstand down in gear to shut down.
« Reply #7 on: September 30, 2025, 06:06:44 AM » |
Ha, I posted a long and excellent response  then noticed it was the kill switch. Deleted. Glad your up and running.
Joe333x
« Reply #8 on: September 30, 2025, 08:05:50 PM » |
Glad you're up and running. It actually takes very little effort to pick up a bike when you do it correctly, just watch some youtube videos. If it falls right put the side stand down, grab the right bar and somewhere on the back of the bike that you can get a grip, push back against the seat with your butt and you can get her up right, right onto the stand. If it falls the other way do all the same and just kick the stand down with your heal once you get it up. https://youtu.be/0IctTgWY5mw?si=9uE-BXWl9vdPoRru
« Last Edit: September 30, 2025, 08:07:35 PM by Joe333x »
Slyk Willy
« Reply #9 on: October 01, 2025, 04:27:17 AM » |
Glad you're up and running. It actually takes very little effort to pick up a bike when you do it correctly, just watch some youtube videos. If it falls right put the side stand down, grab the right bar and somewhere on the back of the bike that you can get a grip, push back against the seat with your butt and you can get her up right, right onto the stand. If it falls the other way do all the same and just kick the stand down with your heal once you get it up. https://youtu.be/0IctTgWY5mw?si=9uE-BXWl9vdPoRruYeah, I did all those things. At 73, I've lost the HP to pick it up. A full tank didn't help either. When my SON in law got here, that's the way he did it. works like magic.
0leman
« Reply #10 on: October 01, 2025, 08:44:42 AM » |
it does come up really easy that way, except when you are on ice. Don't ask
2006 Shadow Spirit 1100 gone but not forgotten 1999 Valkryie I/S Green/Silver
Dirty Dave
« Reply #11 on: November 03, 2025, 02:27:09 PM » |
Cruising along with the Wife on the back, I lost power and coasted to a stop. Tried to start up again, nothing....
Visions of flat beds danced through my head until I noticed somehow, I had tripped the Kill Switch.
I should have known. Nothing stops my Valk in 23 years.....
It's weird being the same age as old people
