February 11, 2026, 03:37:57 AM *
Author Topic: Ye Ole Buzz Bolt  (Read 1483 times)
Rio Wil
« on: September 30, 2025, 02:25:09 PM »
In parting out a frame, I removed the buzz bolt and noticed the clearance between the frame and spacer bar. I did not try torquing down the buzz bolt nut at the time so I didn't notice whether the bolt was tightened enough to eliminate the space between the spacer and frame. NO WONDER THE THING buzzed!
Click on the url to see a pic of the spacer and frame.
https://imgur.com/a/8IbojXy
I just found my pipe clamp and with considerable effort was able to squeeze the frame enough to capture the spacer tightly.   See that pic below...
https://imgur.com/a/V6K8wDS
Based on having to raunch on the pipe clamp really hard, you gotta torque the nut mightly.
« Last Edit: September 30, 2025, 03:03:23 PM by Rio Wil » Logged
Mooskee
Southport NC
« Reply #1 on: October 01, 2025, 08:45:16 AM »
Must be the same tolerance applied to the crash bars and saddlebag rails. ;-)
