« on: October 02, 2025, 04:36:19 PM » |
Just curious, I need to put a new front tire on one of my Valkyries. I've been doing some shopping around getting quotes. I'm honestly somewhat shocked how much they want. Lowest price I've seen is $125.00. The price almost drops in half if I do the removal and mounting back on the bike. Just curious what's it cost in your areas? BTW, no one needs to remind me about how cheap I am.  Edited: Oh, forgot to mention, I already have the new tire so what I'm paying for is just the labor. This has me seriously considering one of those motorcycle tire (manual versions) fixture/machines. Rams
« Last Edit: October 02, 2025, 04:38:23 PM by Rams »
VRCC# 29981 Learning the majority of life's lessons the hard way.
Pluggy
« Reply #1 on: October 02, 2025, 07:43:11 PM » |
Off the bike, mounting with balance is $40 at a one-man motorcycle garage in Barbeque, NC. He does excellent work. I never asked the "on the bike" price.
turtle254
« Reply #2 on: October 02, 2025, 08:04:38 PM » |
Just curious, I need to put a new front tire on one of my Valkyries. I've been doing some shopping around getting quotes. I'm honestly somewhat shocked how much they want. Lowest price I've seen is $125.00. The price almost drops in half if I do the removal and mounting back on the bike. Just curious what's it cost in your areas? BTW, no one needs to remind me about how cheap I am.  Edited: Oh, forgot to mention, I already have the new tire so what I'm paying for is just the labor. This has me seriously considering one of those motorcycle tire (manual versions) fixture/machines. Rams Try this --- https://www.youtube.com/watch?v=ooZePMY2EAQ
Sweet Cheeks
« Reply #3 on: October 02, 2025, 09:27:40 PM » |
With the tire off the bike, the shop I use in Pueblo CO charges $40 to mount and balance a tire.
I‘ve never had them do the removal and installation, so I have no idea of the charge for that.
I am pretty sure my last words will be ... “Well crap! That didn’t work!”
2004 VTX 1300 (sold) 1998 Tourer 2003 Standard
mbramley
« Reply #4 on: October 03, 2025, 03:29:41 AM » |
My local Honda MC dealer charges 40.00 for mounting and balancing.
« Reply #5 on: October 03, 2025, 04:20:17 AM » |
OK, thanks for the responses. I've always taken the front tire/wheel off previously but was hoping to avoid getting down on my knees this time. Discovered I'm allergic to that pain.  Guess I'll suck it up and go that direction. I was simply surprised by the asking price. Rams
« Reply #6 on: October 03, 2025, 07:23:00 AM » |
Just a note as to what I do. I remove the brake rotors before taking in the rim to get the new tire put on. I had one shop bend a rotor while replacing a tire one time, so I remove them every time since then. I didn't find out that it was actually bent (slightly) until I was miles down the road on my test ride after putting the front end back together. I use the blue Lock-tite when putting the rotor bolts back in. My $.018875 Hay  Jimmyt
h13man
Indiana NW Central Flatlands
« Reply #7 on: October 05, 2025, 07:21:38 AM » |
About the only independent and recently Kawasaki dealer of Christian faith, $45 roll in w/ tire disposal 15 mos. ago. Offered to install the beads also but its a pain in the arse with the 90 degree stem so relegate that to myself.  They been doing my tires since 07'.
h13man
« Reply #8 on: October 06, 2025, 07:09:18 AM » |
« Last Edit: October 06, 2025, 07:14:31 AM by h13man »
« Reply #9 on: October 06, 2025, 02:42:21 PM » |
Haven't decided on the labor issue yet, kind of depends on how my knees feel and when the weather is right. Ordered balance beads for this tire change, don't like stick on weights. The balance beads ordered through Amazon. Could not find any locally and the tire shop doesn't stock them.
« Last Edit: October 11, 2025, 02:44:56 PM by Rams »
h13man
« Reply #10 on: October 11, 2025, 06:09:26 AM » |
Did have issue with the stick on weights when reinstalling the rear tire on the Vulcan. Fortunately I seen the spot and was able to do a re-stick. Beads from that day forward.
« Reply #11 on: October 11, 2025, 02:49:50 PM » |
Tire is mounted; balance beads are roaming around inside that tire. Have put about 300 miles on that tire since it was mounted, absolutely no issues. Thanks for the responses.  Rams
h13man
« Reply #12 on: October 12, 2025, 06:28:58 AM » |
On a note, I check pressure @ 10 and 2 o'clock position due to beads hanging up in the 90 degree valve stem thus I do a blow out before doing the actual check. Last time I installed a valve core that keeps beads out of the stem but on the 90 degree it seemed to restrict the air a tad but...
Update: Still have issue with the rear stem with the "restricters" in place but no issue with the front w/o a restricter in them. Honestly I'd be surprised the beads will help on rear tire mileage but a experiment in progress but it always have balance for sure.
« Last Edit: October 15, 2025, 09:03:45 AM by h13man »
