February 11, 2026, 01:50:03 AM *
Author Topic: Wish me luck  (Read 1595 times)
Sixgunluvr
« on: November 03, 2025, 10:00:55 PM »
Whelp, I finally got my barn. Just in time as snow flurries expected next week. Brown barn w/loft was sold   Before I committed so a 10x12 red barn it is.
 I filled up with ethanol free and had no time to run it dry so it’s sitting in the barn with a full tank. Need to start on disassembly so I can get the carbs refurbished, was starting to leak pretty bad around carb #3/fuel rail when I put it away.
  Can I do this with no lift or way to stabilize the bike? Or does anyone have a cheap/easy DIY idea.
I assume first thing to do is get the seat off, disconnect the battery and then start remove petcock/start disconnecting hoses…tank is full so it is what it is.
Joe333x
Boston
« Reply #1 on: November 04, 2025, 03:30:31 AM »
Edit: PDFs should work now, let me know if not.
Use this PDF, I take no credit for this, this is from Dave at https://www.valkyrieflatsix.com/.
Removal
https://drive.google.com/file/d/1aK7V0sbt_ncMjsxvYIEzTcDFuRFHBf2Y/view?usp=drive_link
Installation
https://drive.google.com/file/d/1HsDuwcH3LTVNAgxvJWBdmyFrDouTNCxw/view?usp=drive_link
I uploaded some videos on YouTube on rebuilding the carbs after I cleaned them in an ultrasonic cleaner. I took mine off, set them up on a table in a room and rebuilt one at a time and I was good to go by the time spring came.
Disassembly
https://youtu.be/tx3AnNUVahI?si=XBHIoFeG6k_xUruP
Reassembly
https://youtu.be/qiY2pCfTwMw?si=p2qMvrZV13vTg7QI
« Last Edit: November 04, 2025, 07:32:40 AM by Joe333x » Logged
Sixgunluvr
« Reply #2 on: November 04, 2025, 10:39:43 AM »
I won’t be rebuilding them myself. I have been watching YouTube disassembly and reassembly videos until I am blue in the face. Still need everyone to wish me luck though.  Smiley
« Reply #3 on: November 04, 2025, 12:19:59 PM »
I hope you're following someone's valid directions.  If you filled the tank and then will remove the petcock you will get several gallons of fuel dumped on the engine.
« Reply #4 on: November 04, 2025, 01:34:46 PM »
There is no need to remove the petcock before removing the carb bank
Sixgunluvr
« Reply #5 on: November 04, 2025, 03:19:15 PM »
Yes, I had to store it full. It’s too cold now and don’t have time to run it dry. No I don’t want gallons of fuel dumped on the engine and don’t want to learn the hard way… :)seeking valid directions. Have watched the videos on you tube that people here mention many times.  I will take the seat off, disconnect the battery, then next step is..
Certainly I have to remove the tank and air box?
« Last Edit: November 04, 2025, 03:22:20 PM by Sixgunluvr » Logged
Joe333x
Boston
« Reply #6 on: November 04, 2025, 06:07:53 PM »
Did you download the PDFs I posted, they are very clear directions on removal and installation...
Sixgunluvr
« Reply #7 on: November 04, 2025, 08:31:56 PM »
“Did you download the PDFs I posted, they are very clear directions on removal and installation...”
Yes, thank you.
