January 31, 2026, 02:48:00 AM *
Author Topic: interstate radio/cb question  (Read 3331 times)
clsimmonsjr
« on: February 24, 2010, 12:24:18 PM »
This may be a stupid question, but I have had problems with my radio for years and am bidding on ebay for one.  Here is the dumb question Are the CB and Radio one unit. I always thought I had CB and am almost sure of it, but I just have one box under the seat.  Again, sorry for my ignorance.
Cattman
Franklin, IN
« Reply #1 on: February 24, 2010, 01:33:51 PM »
The CB mounts under the trunk and you would have an antenna on the left side to match the radio antenna.
« Reply #2 on: February 25, 2010, 03:38:34 AM »
Not on any interstate I've ever seen, including mine. It is under the trunk. Hoser   ???
MP
North Dakota
« Reply #3 on: February 25, 2010, 05:27:35 AM »
CB mounts under the trunk.  The radio mounts under the seat.
MP
"Ridin' with Cycho"
Novavalker
99 Interstate/2017 Goldwing
« Reply #4 on: February 25, 2010, 07:19:30 AM »
What problem are you having with your CB?
clsimmonsjr
« Reply #5 on: February 25, 2010, 07:54:55 AM »
well, I got outbid anyway, I'm thinking about going with a J&M system since it is so expensive to replace the stock radio/cb.
Friagabi
Tacoma, Wa
« Reply #6 on: February 26, 2010, 09:09:18 AM »
Radio is under the seat. It has two round 13 wire plugs on about 8 inches of wire hanging out ot it. (and a bunch of other wires) If there is a CB on the system it will be pluged into one of those plugs (the one marked CB) The other plug is marked CD and I have never tracked down the pin out of that plug. The bike will also have two antennas on it.
« Reply #7 on: February 26, 2010, 06:30:03 PM »
If the only trouble you are having with the radio under the seat is the cb does'nt work, it's because you don't have a CB!  It is a separate unit, and it is under the trunk!  It cimes with a harness that plugs into the radio under the seat.  Everything is controlled by the control unit on the left handlebar, with a complex multi function control.  The instructions are in the owners manual.  If you don't have one, get one.  Otherwise good luck on figuring it out!  Just tryin to help, honest.  Hoser
 This one don't got no CB.(only one antenna, stereo works fine though, I played my mp 3 through it using the aux. input.  It's all in the owners manual.
MP
North Dakota
« Reply #8 on: February 28, 2010, 06:57:59 AM »
I have talked to two IS owners who told me they had CB's, but just never used them.  When we looked at their bikes, there was no CB!  They thought they had one, because the button was there on the handlebar.  What hoser said above is correct.  CB uses a second antenna, and the unit is mounted under the trunk.  Bend down, and look up under there, and see if there is a box.
Some use a different CB, mount it elsewhere, and convert the AM antenna for both.  So, it is possible to have CB without 2nd antenna and box under seat, but that is the OEM setup.
MP
"Ridin' with Cycho"
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #9 on: May 09, 2010, 05:49:56 PM »
It was mentioned that some use a different CB. What other options are people using? I like having one a few times a year but always think the money would be better spent on chrome  Cool
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
Grumpy
Tampa, Fl
« Reply #10 on: May 10, 2010, 09:22:26 AM »
Yamaha Royal Star Venture CB, it is a direct plug and play for the interstate, all the factory controls and display work correctly. Just keep an eye on Ebay, I bought one from Pinwall cycle, for $129. Installed it a couple months ago, and works fine.  I did not install it under the trunk as the factory one was, I removed some plastic from the rear of the battery box, and installed it there. It is under the factory am/fm radio.
« Last Edit: May 10, 2010, 09:41:03 AM by Grumpy » Logged
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #11 on: May 10, 2010, 10:15:28 AM »
Are there certain years only that work or any year?
MP
North Dakota
« Reply #12 on: May 10, 2010, 10:55:25 AM »
try  valkyrieblingandmore.com
MP
"Ridin' with Cycho"
« Reply #13 on: May 10, 2010, 03:04:00 PM »
That's good to know, Grumpy, if I ever get another interstate I'll look for one.  hoser
Grumpy
Tampa, Fl
« Reply #14 on: May 10, 2010, 08:26:53 PM »
The one I purchased was from  1999 Yamaha Venture Royal Star XVZ1300, I believe newer years are the same.
