May 12, 2026, 08:31:53 PM *
Author Topic: Ideal for cross saddlebag support for bags  (Read 2133 times)
Warlock
Magnolia, Ms
« on: January 01, 2026, 01:06:55 PM »
A little mod I did to my bike that may help others in the future. When I bought the bike the rear cross bar support for the saddle bags was missing. You can't just order it you have to buy the whole mounting hardware. Anyway I went to lowes and bought 2  elbows conduit metal 3/4 inch and also a connector to join the pieces together. I cut 1 inch off both pipes and measured 3/4 back from the cut off piece and drilled a 1/4 hole in each pipe. Slid them on and drilled thru the bar to secure the 2 90 degree pipes and then coupled them together. Not other cutting needs to be done they work out just right. Here is some pictures. Now the bags are supported better.
David
TTG53#1717
Far West Texas
« Reply #1 on: January 01, 2026, 04:14:17 PM »
Gets my vote !!
‘97 Standard Purple/White
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
