January 28, 2026, 01:44:45 AM *
Author Topic: Had a blowout a long way from home  (Read 555 times)
RatchetRachel
Baytown, Tx
« on: January 06, 2026, 05:28:09 AM »
I had a blowout on my rear tire a long way from home. With it being a saturday night there was no way to get a tire, especially because bike shops are closed Sunday and Monday; so I've had no choice but to go to the darkside! I found a 205/65/16  and I'm wondering no matter the amount of rubbing, should I be ok to make it home 65 miles away?
  From my experiences in life, the darkside is usually not a good place so I don't plan on staying!  Do I need to do the mod?
 --  97 standard , 1 up,  no weight, standard shocks on the highest setting.
--Relentlessly Ratcheting Rachel
« Reply #1 on: January 06, 2026, 07:34:06 AM »
Well how did you get it mounted (with bike shops closed), at a car tire place?
Higher psi is better than lower for rubbing.  Look for the max psi printed on the tire sidewall and put that in.  It should get you home OK.
What car tire did you get?
Gondul
VRCC #408
Central Florida
« Reply #2 on: January 06, 2026, 10:01:14 AM »
 You're likely not gonna fit the tire without the nut cage mod...
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
« Reply #3 on: January 07, 2026, 05:17:24 AM »
To some the dark side is a flawless transfer, to others it's a learned experience and to some its "hell no"
Give it some time.
Nut mod is probably required.
If your saying it's rubbing, you should probably not ride it till it's not, unless you can control it by speed and PSI.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: January 07, 2026, 05:22:48 AM »
I've got to say that, in my experience, PSI is irrelevant to any "rubbing". I've run 205/65-16 size for several hundred thousand miles. The ONLY rubbing has been the nut cage. I run 26psi all the time. This has been on all three Valks at my house.
NewValker
VRCC# 36356
Oxford, MA
« Reply #5 on: January 07, 2026, 05:54:45 AM »
Go with a 195, no rubbing. 40 psi.
Craig
Turns out not what or where,
« Reply #6 on: January 07, 2026, 09:35:13 AM »
I run the 205/65-16, zero rubbing and lower rpms about 200. 30k miles now on the tire. sometime this yr will need a new one.
« Reply #7 on: January 08, 2026, 05:53:22 AM »
Agreed, PSI may not make any difference with the fender, I can't say, because I did the nut cage on both my Tourers and my Interstate when I installed the first Dark Side on them.
Is the OP riding a Standard?
It may make a diff in the swingarm clearance. Tire brand could make a diff also, maybe.
26psi is on the low side, so if you didn't/don't have an issue, most others would probably not either.
Draeger
Nanaimo, British Columbia
« Reply #8 on: January 21, 2026, 11:28:45 AM »
Did you need to do the nut mod ?
If you are distressed by anything external, the pain is not due to the thing itself, but to your opinion of it; and this you have the power to revoke at any moment. ~ Marcus Aurelius
Valker
Wahoo!!!!
Texas Panhandle
« Reply #9 on: January 21, 2026, 04:19:38 PM »
Yes. Rubbing on the right side of the tire. Not severe, but enough that I wanted to stop it.
