January 19, 2026, 07:38:15 PM *
Author Topic: Man do I suck at bathroom caulk work!!  (Read 338 times)
« on: January 14, 2026, 08:38:57 AM »
I have really lucked out to have a new neighbor a couple doors down who is a general contractor who does high end house remodeling/restoration with a crew of experts and on-call tradesmen in just about every field.  We've helped each other out a number of times around our houses, have a common interest in conservative politics, motorsports, bikes and firearms, and get along famously.
I told him how badly I was gouged by the local plumber business (I've used a number of times over the years), and that I needed a couple small repairs, and he said he had a pro he keeps busy on all his projects and brought him over yesterday.  Nice young guy and the three of us did a walk around looking at the work.  The guy instantly diagnosed my problems, will order a few parts, I went to Home Depot for a new fixture, and he will also replace all my ancient hose bibs.  (I'm certainly going to pay him, but it will be about half what I could expect from my local plumbers).
So my contractor buddy looked over my half bath shower stall that had new tile done a few years back and told me I needed to get in there and point up cracks that have appeared since the work was done before I get real water damage in the walls.  (I knew this, but have been putting it off.)
So I reluctantly got in there this morning, dug out bad caulk and went at it with new.  Even with nitrile gloves and soapy water, I cannot lay a fine bead worth a damn, smear it all over the place, step and sit on the tube of caulk (it's a small shower stall).  This work requires patience and skill, and I have neither.  It takes me three times as long to clean up my mess (and a pile of rags) as it does to run the caulk.  It's not the neatest job, but all the cracks are sealed up.  tickedoff
« Reply #1 on: January 14, 2026, 08:44:47 AM »
The spousal unit and I had a bit of a tiff over that a few years ago.... She insisted on using gloves and was making a huge mess, getting it everywhere but where it needed to be...
I'd never laid caulk before but it seemed simple so I asked her to let me try.
Went at it with one hand holding the end of the caulk gun with my finger (No gloves!) near the exit smoothing the line as it came out, as it was being pumped by my other hand.
Went smoothly and easily, no problem. Little soap and water afterwards got the caulk off my finger...
Now, the cleaning out the old part of that operation? No thanks! HATE that part!
« Reply #2 on: January 14, 2026, 09:15:56 AM »
The biggest mistake beginners make is too big a cut in the nose of the calk tube. The cut should be no wider than the width of the desired finished bead of calk. When you run a WET finger over that laid calk calk should get pushed into the crack and smoothed evenly without much ending up on your finger. If it takes three rags for each line you lay. That’s too much calk/too bit a cut
« Last Edit: January 14, 2026, 09:34:41 AM by Chrisj CMA » Logged
bassman
« Reply #3 on: January 14, 2026, 09:41:04 AM »
Blue/green tape could possibly be a friend.  I too use to suck at chalking but a friend told me to use the blue/green painters masking tape.  Tape both sides of the line to be chalked, cut tip off tube using Chrisj CMA advice, chalk, wipe  wet/soapy finger to smooth it out (no rubber gloves for me), remove tape and you should have a pretty decent chalk line in place.  I've watched pros use the masking tape trick also.  It does take time to tape it off but it's a little easier than taping for a paint job where it has to be more accurate.  Might be worth a try in the future.......Good luck!
« Reply #4 on: January 14, 2026, 11:37:02 AM »
Well, my principle problem was the tip of the good bathroom caulk I had was already cut for wider work, and I didn't want to go buy more (in traffic) just for this little job.  That's why I wore the nitriles.  But you're absolutely right Jeff.  And it wasn't gun caulk it was just a big soft tube (I'm better with a gun caulker, and will never buy the soft tube stuff again).  The other main problem was the small space in that shower stall, and I had to kneel and sit in there and work in tight quarters which is hard on my old body.
My buddy the contractor offered to have one of his guys do it for me, but I was embarrassed to ask (right after he got me a good plumber).
The painter's tape is a good idea, and I have some, but didn't relish the extra crawling around in there it would have taken.
It's all cleaned up now, and I went back over the whole stall with this new ceramic wax and shine.
I shower in the evening, but not if it's not fully cured I won't.
Man it's 50 out there and it won't be this warm again for weeks.  I was hoping for a short ride this afternoon, but it's lead gray skies and a chance of rain (miserable) so no ride for me.
« Reply #5 on: January 14, 2026, 12:05:10 PM »
Well, my principle problem was the tip of the good bathroom caulk I had was already cut for wider work, and I didn't want to go buy more (in traffic) just for this little job.  ...
LOL!  Some of success is influenced by skill.  Much is impacted by the choice of tools.   Wink
« Reply #6 on: January 15, 2026, 06:00:13 AM »
What I've learned from installing miles of caulk over the decades is the very best tool for smoothing a line is the human fore finger.
The main rule is to limit how much you put down.  You can always add more, but removing extra is sometimes difficult and messy.
Painters are the best at this work.
The Paintable caulk is easiest to work, as clean up of your tool (finger) and the surface it's applied on, is with water and paper towels.
Rarely was painters tape used for caulk work.
« Reply #7 on: January 15, 2026, 06:21:50 AM »
I'm a little hazy on caulking over tile grout (cracks and crumbles).
I'm never doing grout.
The saving grace of my repair work was that everything is white; the tile, the grout and the caulk.
« Reply #8 on: January 15, 2026, 09:58:57 AM »
I think you’re making a mistake there. All white, easy peasy. You can buy a premix white tile grout in a small tub, apply with a small grout float, wet (damp) sponge to remove the excess. Not sticky and stringy like a caulk. Caulk or grout remove the loose grout first, better results lasts longer.
« Reply #9 on: January 15, 2026, 11:03:05 AM »
Thanks John, my grout cracks were mostly hair line tiny (except the floor edges, which was already caulk, not grout).
If my caulk fails, I'll try the premix grout next time.  (I did not know there was premix available)
« Last Edit: January 15, 2026, 11:56:51 AM by Jess from VA » Logged
« Reply #10 on: January 15, 2026, 11:21:16 AM »
Thanks John, my grout cracks were mostly hair line tiny (except the floor).
Gotcha, hope it lasts along time for you.
« Reply #11 on: January 15, 2026, 12:25:48 PM »
Me too John.
My bigger problem is the concrete block retaining wall in my backyard 3-level split lower level walkout (6 steps).  That thing was failing when I bought the home 35 years ago (with some shoddy patchwork readymix repairs).  30 years ago, I had concrete walks poured all down the back of the house, and for many years I had no problem, but eventually the water still got down between the sidewalk and retaining wall, and I did harry homeowner fixes many times that only slowed the erosion.
Then two years ago the two sections of sidewalk butting up to the retaining wall got eroded badly enough, the inside edge of those two sections dropped about two inches, and I finally did a good repair with digging everything out I could, mixing concrete and getting it as far down in there as I could; a lot of concrete, and I thought I finally had it licked.  But with the 2 inch drop always retaining rainwater, the crack has again appeared (very small).
I just got done again grinding out the crack and filling it with silicone which is a good seal for now in winter, but will not last.
My neighbor the contractor eyeballed it for me and said there are foundation experts who can drill holes in the walk and shoot hydraulic cement under it and raise it back to level (NOT level but slightly angled away from the house and retaining wall, and fully/permanently seal the sidewalk and retaining wall joint.       And he will find me a contractor who will not gouge me for the repair.
I had been told about this before, but have resisted the expense.  But I must do it (and give up my harry homeowner ways) or that wall may eventually cave in and be a nightmare (and thousands more) to fix.
I asked my contractor buddy if there was ever a time when owning a home stopped costing so much to keep up.  NO, Jess, it never stops.  tickedoff
I apologize for sharing my tales of woe, but I am wholly untrained in this sort of thing, and any advice or suggestions would be greatly appreciated.
« Last Edit: January 15, 2026, 05:20:45 PM by Jess from VA » Logged
« Reply #12 on: January 15, 2026, 07:00:30 PM »
Heh.... I quite enjoyed copy and pasting that to Kali. Her and her newly wed husband closed on their first house yesterday. I've been trying to explain to them "A Man's House is his Hassle" is more than a witty phrase.
(I will say, in an age where most young professionals have a hard time getting a house, big props to the military! 23 year old E4 and 21 year old E3 just bought a new build $300k house with no money down quite easily...)
« Reply #13 on: January 16, 2026, 03:03:10 AM »
Well good for them Brian (I think).
Buying equity beats paying rent, but it's a big step and responsibility, and monthly nut($).  And I hope they are a happy couple who continue loving each other.  Money issues in young married people is often a big problem leading to discord.
I was a dormitory, renter, military housing guy until I was 40, got out and drove cross country to a USDVA job in DC.  My dad (the smartest man I ever knew) warned me about used homes and told me to take plenty of time choosing wisely.  I didn't listen, found my current home in days, had some pencil whip walk through inspection and bought a place with multiple serious problems that continue to this day.  The fact it had been listed for sale for some time should have rung warning bells.
Hopefully, new construction means no serious or even minor problems.
« Reply #14 on: January 16, 2026, 05:51:49 AM »
She went into it eyes wide open.... The builder conveniently provided their own inspector who said everything was A-Ok! so she hired her own inspector who found lots of little things and a few medium ones.
Delayed the closing by nearly a month, but the builder corrected all the issues, then after the builder's inspector once again said A-Ok! she had HER inspector go through again to make sure.
Does make me feel really REALLY old though, having my eldest a married home owner!  Lips Sealed
« Reply #15 on: January 16, 2026, 06:45:04 AM »
Congrats to Kali and her man for hiring a second inspector.  I watch a ton of reels on the book of faces by a guy that ends all of them with "That Ain't Right".  He finds all sorts of things that the builders inspector didn't.  But, the builders inspector is working for the BUILDER ! not the buyer.
We are getting old my friend....
Hay  Cool
« Reply #16 on: January 16, 2026, 06:48:31 AM »
Since I've managed to threadjack Jess' fine thread on caulk, here's a pic...
« Reply #17 on: January 16, 2026, 06:51:21 AM »
AWESOME ! ! !
Hay  Cool
« Reply #18 on: January 16, 2026, 08:41:54 AM »
Nice new house, with a 2 car garage.  And fresh sod (that will require water).  cooldude
I wish them great joy and happiness going forward.
Hijack away my friend, I do it all the time (because it's easier than starting a new thread).
Old hell.  What are you, like 52?   Grin
My only niece, who I only knew as a child before shipping out for the Air Force, is now 40 something.  With a boyfriend for years 10yrs her senior who is a great guy (and contractor out at Area 51 LV or as she calls it "Secret Squirrel Land", so I know he's vetted out the wazoo).  No nuptials are forthcoming (poor girl can't have children anyway), so why bother?
It always tickles me to be called Uncle Jess.
« Reply #19 on: January 16, 2026, 09:50:23 AM »
Wasn't the uncle on the Dukes of Hazzard named............   No, that was Uncle Jessy.
Hay  Cool
« Reply #20 on: January 16, 2026, 02:37:22 PM »
Hay  Cool
Technically, Jessy is the girl's spelling, and Jesse is the boy's.  But the spelling has always been all over the place with both genders, and even Jessi.
I can't tell you how unhappy I was with my name at 5-10 years of age.  I got constant ribbing and joking from the neighborhood boys about having a girl's name.  I took to punching guys for it, and got in trouble for it.  And once they knew it got my goat, it just got worse.  And I was given no middle name as my folks thought that was unnecessary, or I would have started using that name instead.  Even though my dad was Richard Henry, and mom is Grace Helen.  My brother Paul didn't get a middle name either, but that wasn't a girls name.  My sister was named Mary, and all three of us were given names from the Bible (at that time, both my folks were Sunday school teachers).
I did go with Jess instead of Jesse at that time, and ever since.
(I haven't thought about this for 60 years.... thanks for reminding me.   2funny tickedoff )
« Last Edit: January 16, 2026, 03:12:32 PM by Jess from VA » Logged
« Reply #21 on: Today at 10:51:33 AM »
Hay  Cool
Hmmm...   I have no middle name either....  My father was Jimmy and I am Jr.  My son is III and my grandson is IV, all with no middle name.  My brothers were named David Mark and Joseph Scott, both taken from the Bible as yours was.
Hay  Cool
« Reply #22 on: Today at 12:35:22 PM »
Well at 5-10 years old, I would have been happy as hell to have been a Jimmy... or John, Bob, Bill, Dave, Mike, or any other unmistakable male name.
Of course I've grown used to my name now for many years.  Though when I say Jess, I occasionally get called Jeff anyway. (no, I don't have a lisp)   Grin
As far as no middle name, I've spent a lifetime having to fill out Govt forms, security statements or background investigations where the middle name is NMN (no middle name) or NMI (no middle initial) (as some get an initial with no name).  But not for a very long time.
_______________________
My new plumber just left, and about 5 hours work was only $850 (few parts, mostly labor).  Very nice guy, solid and skilled worker who will get all my business from now on.
The County water and sewer people have been trying to sell me insurance on water and sewer repairs (from street to your house is on you), and I've been throwing that mail away for years.  But my plumber told me if my sewer goes out it could be $15K or more, and water $5-6K and if he owned my home he would buy it (couple hundred a year).  My home is some 60 years old, and I've fixed every other damn thing imaginable.  So now I'm thinking maybe it's not a bad idea.
Thoughts anyone????
