March 05, 2026, 09:38:50 PM *
Author Topic: Portable phone charger/jump starter/flashlight/air compressor  (Read 384 times)
« on: February 23, 2026, 06:24:02 AM »
We've discussed the small portable batteries capable of charging your phone and jump starting your car or bike here a few times, I always travel with one. It seems they've added a new capability to the mix - air compressor...
Just took delivery of one of these, will kick the tires, inflate the tires and if it passes inspection will replace a few things on my bike for trips.
Anyone else tried one of these?
This is the one I went with. Lot of capability for under $50 currently...
https://www.amazon.com/dp/B0FMD8Z8K2
First impressions seems build solid but that's just first impression...
« Reply #1 on: February 23, 2026, 07:04:00 AM »
That clamp type has failed on my on other compressors so I like the ones you have to
actually screw on the valve stem now
Mine just is for air, not jump starting
Nice price point though
And I used mine today as I had gotten a nail in my rear tire. Got me from Yankee Stadium (actually parked right in front of it on River Ave to my mechanic near my office)  It took more than 5 minutes to go from 16 to 33 lbs pressure
« Last Edit: February 26, 2026, 06:54:49 PM by Oss » Logged
GiG
NEAR the "In 'n' Out Burger"
« Reply #2 on: February 23, 2026, 07:27:43 AM »
Cool!   cooldude
I recently bought one similar to keep in the truck (tire psi fluctuates in cold weather, causing
TPS Driver info alerts )
Past experiences is: small compressors get hot & fail…
Screw on type hose lose a few psi when un-screwing…
Everything is - Nothing is .
(send it to OSS)
This isn’t Rocket Surgery
mellowyellow#7933
Verner, Ontario, Canada
« Reply #3 on: February 24, 2026, 04:43:40 AM »
Will it work on a completely dead battery? A few years ago at the DRU I left my key on overnight, no problem, took out my jump starter and... nothing. Rainman had one also but same thing. Apparently some require a small amount of power to activate. Project Farm has a few good videos on various brands.
I am considering a Gooloo 4000, available at Walmart in Canada.
« Reply #4 on: February 24, 2026, 07:32:45 AM »
I had this issue with my dad's car just last week... Even my plug in charger wouldn't recognize the battery.
I disconnected the positive terminal from the battery and then it would charge the battery. Was very odd...
GiG
« Reply #5 on: February 24, 2026, 07:57:37 AM »
Yeah,
All of these supposed SMART modern features will sometimes hold you back…
 tickedoff
(send it to OSS)
F6Dave
« Reply #6 on: February 25, 2026, 01:39:51 PM »
My first long motorcycle trip was in 1977. I rode 5,300 miles on my nearly new KZ-900. I went from Colorado to New Jersey, returning through New York, Ontario, Michigan, Wisconsin, and Minnesota. Along the way I had flat tires and a dead battery. But I was never stranded.
In upstate NY I had to replace a poorly wearing front tire in the parking lot of a motorcycle shop. Later that day I got a rear flat just outside of Lake Placid. Those were the days of tube tires, so I carried spare tubes and a few patches inside the fairing. Those Vetter Windjammer fairings had enormous storage space inside.
To inflate both tires I used a 'spark plug inflator'. These consisted of a hose with a fitting for your valve stem on one end, and an air intake and pump on the other. You threaded the pump into a spark plug hole and ran the engine at idle. A diaphragm and one-way valve made sure you inflated the tire with fresh air, not fuel. It worked very well and inflated a tire in a minute or so. The device is shown below, and still sits in my garage.
In Michigan one morning my battery was dead. Upon inspection I found it to be completely dry. I filled it with water to no avail, and later discovered a bad diode on the rectifier board that overcharged it.
But that didn't interrupt my trip. Some of those early bikes with electric start also had a kick starter, partly because traditional bikers didn't trust that new tech stuff. So I continued my trip through Upper MI, WI, MN, and NE using the kick starter. The bike ran just fine.
Bigwolf
Cookeville, TN
« Reply #7 on: February 25, 2026, 05:02:55 PM »
I used to carry a Rugged Geek complete with air pump in my saddlebag.  But then one day I found it had swollen up and split it's case.  It no longer resides anywhere near my bike.
mbramley
Painesville Ohio
« Reply #8 on: March 02, 2026, 05:17:45 AM »
 I use the NOCO brand jump starter, I think GB40 size. It has a button you press when the battery is to low to recognize. It came in handy when I left my plow drop switch on and it would completly drain the battery before the next snow. I usuall get multiple jumps before needing recharged although I recomend charging it every month or two. I had one to low to jump a car once, of course we were in the middle of a cold spell of negative tempertures at the time.
Timbo1
Tulsa, Ok.
« Reply #9 on: March 02, 2026, 09:36:16 AM »
Looking forward to a followup review after you've had some usage.
I've been carrying the following two devices for about 3 years now and they've both been great for car and bike but anything to save some space is always a good thing.
Compressor
Boost Box
