March 05, 2026, 09:42:28 PM *
Author Topic: My old deck is an embarrassment  (Read 411 times)
« on: February 26, 2026, 01:12:16 PM »
Built on the ground off the back of my house over 30 years ago, out of the 'good' pressure treat, 24 feet wide by 16 foot long.  Only a hack carpenter myself, but back then I had a retired Navy chief neighbor who was a master carpenter, and we got along famously.  Me just out of the Air Force (9 yrs), we would trade military stories, and drink a lot of beer.  He was an old Alabama boy, had been a deep water sailor all over the world, and funny as hell and kept me in stitches.  He taught me to use the tools, and measure the wood and he would supervise while I worked.
When finished, I sanded and stained it, and it looked like a beautiful gymnasium floor.  He was also an expert electrician, and we ran 220 out there and put a very nice Jacuzzi 4 man hot tub on it, as well as a 5 foot tall concrete fountain (which was a big mistake with water damage over the years).  The wife and I would entertain with other couples out there.
Fast forward to today, the fountain is gone and so is the Jacuzzi.  I no longer use the deck for anything but a work area (occasionally).  Age, water damage and rot are covered with pieces of scrap lumber, mostly plywood, but also a patchwork of 1X4, 1X6, 2X4 pieces.  I've stained it down dark to sort of hide the embarrassment.  I just came in from covering two new holes my foot could go through.  Grin
I've thought about repairing it, but it would take 23 pressure treat eight foot 2X6's ($$), and hours yanking out 4" twist nails with a crowbar, but I'm not doing it.  (Only a few of the deck boards are bad all the way across, most are just bad on one end, and the frame underneath remains good and solid.)
Fortunately, it cannot be seen from the street/sidewalk (and the nice handrail around the outside which can be seen is still in excellent shape).  It's just a hard use work area that is rarely used.
I do not post my own pictures on here and would be too embarrassed to do it if I could.  crazy2
« Last Edit: February 26, 2026, 02:24:39 PM by Jess from VA » Logged
da prez
Wilmot Wi
« Reply #1 on: February 26, 2026, 02:15:14 PM »
  Do a little destruction bit by bit. It will soon disappear.  A stone step and pavers will clean it up.
                                     da prez
« Reply #2 on: February 26, 2026, 02:28:24 PM »
Ross, it's still a solid deck (with solid though ugly repairs), I'm not going to tear it off.  It just doesn't look very good.
I have a lot of stone around the place too.  It doesn't wear out.   Smiley
« Last Edit: February 26, 2026, 02:31:57 PM by Jess from VA » Logged
« Reply #3 on: February 26, 2026, 03:22:59 PM »
My brain swapped the e for an i and I was thinking WoW! Ole' Jess is REALLY oversharing these days!
But seriously... Repair/replace the structurally bad boards, then cover the whole thing in outdoor carpeting?
« Reply #4 on: February 26, 2026, 04:27:12 PM »
My brain swapped the e for an i and I was thinking WoW! Ole' Jess is REALLY oversharing these days!   2funny cooldude  My e for i, is doing remarkably well.  Good thing since I have to pee through it 47 times a day.   tickedoff
I'm not replacing 23 eight foot boards on a deck I use maybe once a month, and if I did, covering a deck with carpet is a terrible idea.  But thanks for weighing in.   Smiley
« Last Edit: February 26, 2026, 04:31:26 PM by Jess from VA » Logged
Jersey mike
Brick,NJ
« Reply #5 on: February 27, 2026, 03:53:00 AM »
If just the surface boards are in bad shape, then you still have something to build on. Is everything on 16” centers?
You could either go the easy way with pressure treated 3/4” plywood and throw some of that outdoor grass carpet over it or have a pro come in and fiberglass it or have a pro come in and put a decking product similar to Trex installed.
« Reply #6 on: February 27, 2026, 07:01:54 AM »
I believe it is 16" on centers.
I'm not fixing it beyond what I've done, although I have some better plywood I can use when the weather is warmer and will get out my circular saw.  I still have piles of ice back there from the big storm 3 weeks ago.
I'm not paying anyone to do what I won't do.
With a deck that will likely require continuing repair, I would never cover it with carpet which would hide the damage and have to be removed for additional repairs.
If I really feel energetic, when it warms up and I get it better repaired, I will power wash it and stain it again (mainly for weatherproof, not looks).
« Last Edit: February 27, 2026, 07:23:18 AM by Jess from VA » Logged
Jersey mike
Brick,NJ
« Reply #7 on: February 27, 2026, 10:10:20 AM »
Sorry Jess, it seemed as though you didn’t want to have a dangerous situation on hand and didn’t want to be the one pulling up the old P/T lumber. I was just trying to offer up some new options that would be available in case you were interested in something else.
« Reply #8 on: February 27, 2026, 11:21:51 AM »
No apology necessary Mike, this post was intended to invite comments, suggestions and ideas.
And to make guys laugh.   Grin
I covered the two new holes, so there's no more danger (although some of my patches are small trip hazards).   crazy2
« Reply #9 on: February 28, 2026, 07:12:06 AM »
Cover it with metal roofing.
Just kidding.
If the joists and beams are still structurally sound, replacing the deck should not be overly difficult and should take 2 competent carpenters about a day, based on your stated size.
But, then there's guard system and stairs, if any.
My 35+ deck is starting to show its age, but so am I, so we'll age together.
Some of the deck boards are comprised and need replacement, so I just don't look there and stay clear when walking by.
« Reply #10 on: March 01, 2026, 04:53:57 AM »
Just kidding.
The deck sits on the ground Bill, so there's just one easy step up from the concrete walk that runs to it.
The outside handrail (4X4 uprights with lattice) is perfect.  The underlying framework is good.
The inside half of the deck that butts the house is also near perfect.  But the outside corner that had the stupid water fountain on it is patched with plywood which is mostly solid, but has some spongy spots I avoid.
With no garage, I stored a bunch of scrap lumber and plywood by screwing it vertically to my 7' fence behind the 2 sheds and covered it with vinyl sheeting, so it has stayed pretty solid (and I did such a good job I have not wanted to rip it all off to use for salvage).  All my previous patches have been made with whatever I could find, a little at a time, and it shows.
I've decided what I need to do is uncover it and see what I have, and/or buy new plywood, tear off all the old patches and do a better job than the hodgepodge that's on there now.
I will not restore it properly with deck boards, but I will do a better more solid plywood repair.  Eventually.   Smiley
« Reply #11 on: March 01, 2026, 06:38:59 AM »
I definitely get it Jess.
Lately, my attitude on house maintenance is "It's only got last as long as me"
h13man
Indiana NW Central Flatlands
« Reply #12 on: March 01, 2026, 06:51:15 AM »
I'm looking at 32 yr. old 10'x12' deck removal this year but @ 26" above ground level. Sawsall will be the primary removal tool.
« Reply #13 on: March 01, 2026, 05:41:37 PM »
That's exactly my attitude too Bill.   cooldude
After all the discussion in this thread, I got out there today (breezy 50) and uncovered my wood, and found some good plywood, and spent all afternoon improving my patchwork.
Got out the tape measures, hammer, drills, screws, builder's square, circular saw, pry bar, but none of that makes me a good carpenter.   crazy2
All but one of my poor spongy old repairs is now solid (for a while anyway).
The last one needs a much bigger piece of wood than I have, but it won't let your foot go through unless you jump up and down on it.   Grin
« Last Edit: March 01, 2026, 06:45:14 PM by Jess from VA » Logged
Jersey mike
Brick,NJ
« Reply #14 on: March 02, 2026, 04:08:58 AM »
 cooldude Safety first Jess.
Worry about ascetics later when the time is right and the weather is more cooperative.
« Reply #15 on: March 02, 2026, 06:12:05 AM »
It's just an old beat up patched deck.  The rest of the yard back there is pretty much a mud hole anyway, although having the two giant old oaks back there severely trimmed back will let more light back in for grass, I'm not going to try and get lawn going.... the heck with that.
My contractor buddy told me to just tear it off.  No way I'm doing that, and just make more mud hole.
It remains a good dry work area for other projects, and now safe to walk (or drink beer) on.    Smiley
« Last Edit: March 02, 2026, 06:13:51 AM by Jess from VA » Logged
« Reply #16 on: March 02, 2026, 11:27:11 AM »
I needed stuff at the Home Depot this morning, and while there I looked at plywood.
Holy crap is that stuff expensive.
They sell smaller pieces than 4 X 8', but I failed to measure the last piece I need to complete my final repair.  But at those prices I'll probably just use some more old stuff I have laying around.
