January 30, 2026, 12:29:16 PM *
Author Topic: IS helmet locks  (Read 2769 times)
cef2lion
Central PA
« on: February 26, 2010, 10:46:44 AM »
I'm adding an IS trunk to my tourer. I pulled the lock out of the trunk to see if a local locksmith can re-key it. I was going to see if they can do the same for the two helmet locks. I can't see how to remove the helmet locks from the trunk frame. Does anyone know. I reviewed the Honda Direct Line diagrams and it shows some sort of bolt. Mine looks like the end of a rivot.
Craig
DFragn
« Reply #1 on: February 26, 2010, 11:22:23 AM »
Not that my experience holds water, but I took my trunk lock cylinder in for re-keying and was informed that this particular lock could not be re-keyed without damaging it (destroying it).
I don't know about re-keying the helmet locks. But a visegrip will remove the tamper proof assembly from the trunk frame.
Red Diamond
Beaumont, Texas
« Reply #2 on: February 26, 2010, 11:28:52 AM »
If the lock smith can re-key it to the trunk lock, that same key should fit the helmet lock. Normally there is only one key on the Valk that unlock or lock everything. In your case the trunk and the attachments hopefully came from the same bike. The alternative is to have the trunk lock reset to the ignition key of your bike, that way you won't have two sets of keys. Good Luck.
Trynt
So. Cen. Minnesota
« Reply #3 on: February 26, 2010, 12:16:50 PM »
Center punch the rivet heads. Then remove the heads by drilling them away with the appropriately sized bit.
Oyeaa
« Reply #4 on: February 26, 2010, 03:34:53 PM »
They are held on with tamper proof screws, not rivets, you can drill them out like rivets but you will not be able to remount them.
Take your favorite channel locks or vise grips and grip the screw head and turn counter clockwise.  I removed mine that way and you can too but it is a difficult task as they are not made to be removed.
Friagabi
Tacoma, Wa
« Reply #5 on: February 26, 2010, 07:44:43 PM »
Lots of luck rekeying the locks. Now, if you can get the number off the ign switch for the bike they came off you can have a key made.
cef2lion
Central PA
« Reply #6 on: February 26, 2010, 08:12:10 PM »
I have the key for the trunk and helmet locks. I'm just trying to see if I can get them changed to match my bike. If not that is ok.
Craig
« Reply #7 on: February 27, 2010, 06:17:16 AM »
Instead of taking the locks off cant you take the support bracket off with the locks still attached?
Kingbee
VRCC# 576
Northern Illinois
« Reply #8 on: February 27, 2010, 06:27:29 AM »
When I did my trunk install, I had the trunk keyed to the bike, no-go with the helmet locks.  Didn't want another key on my ring, so I just used velcro to store the key in the trunk
1999 Interstate
2000 Interstate
2004 Rune
Trynt
So. Cen. Minnesota
« Reply #9 on: February 27, 2010, 06:36:31 AM »
I replaced the screws with allen headed bolts.
« Reply #10 on: February 27, 2010, 08:41:24 AM »
Do people steal helmets?  ??? When I did wear them, i'd leave them on the seat or if it was windy, on the ground next to the bike. Never had a problem.
Kingbee
VRCC# 576
Northern Illinois
« Reply #11 on: February 27, 2010, 08:51:42 AM »
Between the cost of a good helmet, and the cost of a good headset, you could be at $500.00.
Do you want to leave that on your seat?
1999 Interstate
2000 Interstate
2004 Rune
« Reply #12 on: February 27, 2010, 09:26:09 AM »
Ah, you make a good point.  cooldude I guess no one wanted my $50 3/4.  Undecided
cef2lion
Central PA
« Reply #13 on: March 02, 2010, 10:50:14 AM »
I dropped the trunk core and helmet locks, still attached to the trunk frame, at a local locksmith yesterday. They have a good reputation in the area. I said no hurry. They called this morning and said all the locks were re-keyed to match my bike. He did need to remove the helmet locks from the frame. He locked onto that special bolt and they loosen up and was able to reuse the bolt.
Craig
