May 12, 2026, 07:28:45 PM *
Author Topic: Interstate LCD screen not working  (Read 909 times)
longrider
Vernon, B.C. Canada
« on: May 02, 2026, 07:52:32 AM »
The LCD screen on my IS appears to have an intermitent connection.  This started a few days ago.  It will power up with the key sometimes but not all of the time.  The backlight and fuel gauge always work.
Does the radio relay I see in the schematic only power up the radio/clock LCD display?   Where is the location of the relay?   Any other suggestions.
Warren
« Reply #1 on: May 06, 2026, 11:48:50 AM »
The only time I have seen the screen go blank is when the battery is very low.  When my alternator failed, the screen went blank as the battery was dieing.
Hay  Cool
longrider
Vernon, B.C. Canada
« Reply #2 on: May 08, 2026, 07:12:01 AM »
thanks   The battery is only one month old and voltage is right up there as I tested with the meter for cranking voltage.
Mooskee
Southport NC
« Reply #3 on: May 08, 2026, 04:33:39 PM »
Warren
Check the radio and or CB connections. I removed the radio gear and controls from my trike. That left only the fuel gauge operational on the screen.
