I know that with a 110/220 power supply an intermitent ground can cause voltage spikes and wreck a lot of electric devices.
When I bought my 98 Standard I trailered it through a monsoon rainstorm. When I got the bike off the trailer it started and ran long enough to get it into the garage, then it quit and would not restart. About 4 or 5 days later and after many tries and battery charges it started and ran like nothing ever happened.
Since then I've sprayed every conection and switch I could find with Corrosion-X and made sure the ground is clean. No further problems.
I know you must be as relieved as I was
