January 30, 2026, 03:29:05 PM *
Author Topic: ticking sound from handlebar?  (Read 2567 times)
franco6
Houston, TX
« on: March 04, 2010, 01:07:47 PM »
it started acouple of months back a single [ tick] at stop, moving the handle bar . now its more often .its a neat light metal to metal tick as one gets sometimes turning a bolt. is this indexing ?
i m gonna have to take everything a part anyhow as its time for inspection.
bearing preferences?
the big draw back is no rides!
funny! at the mid winter get together in Austin the other day,the only bike that would not start saturday morning was the    hardley . 2funny crazy2
Enjoy the ride!
N8171S
Marlboro, Mass
« Reply #1 on: March 04, 2010, 01:21:11 PM »
Check the pinch bolts at the top of the fork tubes.  I had one that was not tight and had same symtoms.
« Reply #2 on: March 04, 2010, 01:33:23 PM »
I concur.  Try everything that has a bolt or nut. The whole front end from the risers to the wheel.
Make sure all is tight and correct. Don't pass up anything, thinking it's Ok!
There are too many other possible reasons for the "tick" before you start thinking the steering bearing are indexed.
That should be the very last possibility.
RLD
'99 I/S Red/Black
Eden Prairie, MN
« Reply #3 on: March 04, 2010, 01:35:04 PM »
Not that it couldn't, but mine never "ticked" when it was indexed. It just found a "center" when on a lift.
Dress for the slide, not the ride. ATGATT
VRCC #2505
Thunderbolt
Worthington Springs FL.
« Reply #4 on: March 04, 2010, 04:27:02 PM »
underneath the tree.  I had one of the large riser attachment bolts that was a little loose, and seems like it made a noise when stopping.  I kept lifting/pushing things until I found it.
franco6
Houston, TX
« Reply #5 on: March 04, 2010, 08:37:02 PM »
  cooldude:thanks guys i ll check everything first before going in.it happenned when braking hard, 2up ,mostly front brakes.now it does it whenever!
Enjoy the ride!
« Reply #6 on: March 05, 2010, 06:30:02 AM »
It's a pad in one of the calipers on the front.
It is clapping against the rotor that causes the noise.
Could be they are worn to the point where they need replacing but that is not necessarily the end life of the pad.
Change the pads and the noise will stop.
junior
new hampshire
« Reply #7 on: March 06, 2010, 01:42:46 AM »
it couldnt be the handlebar bearings? i have heard they get flat spots in them from lack of riding  crazy2
franco6
Houston, TX
« Reply #8 on: March 07, 2010, 04:12:41 PM »
 started from the top undid the 4 screws that old the handle bars and retightened them .next the 2 ,19 mm nuts for the risers the right one took a quarter turn     BINGO! no more noise ! Grin
Enjoy the ride!
Thunderbolt
« Reply #9 on: March 07, 2010, 05:49:08 PM »
thanks for posting the results. Smiley
