deadvelvet
« on: March 11, 2010, 01:21:15 PM » |
i cant figure out where its coming from any ideas?
3W-lonerider
« Reply #1 on: March 11, 2010, 01:25:43 PM » |
i'd say your fork seal is leaking
DFragn
« Reply #2 on: March 11, 2010, 01:26:54 PM » |
Probably a fork seal leak. Could be a leaking banjo connection at the caliper or bleeder.
Wipe everything down including the brake lines up to the lower triple clamp and monitor the clean lower fork leg too.
I doubt it's brake fluid unless you had a recent brake job or damage to the lines or bleeder.
« Reply #3 on: March 11, 2010, 01:33:20 PM » |
I concur with the others. My left went out on the way to Cheaha. Perform the 'film trick' and it may work for you. It did for me for a little while.
deadvelvet
« Reply #4 on: March 12, 2010, 03:22:36 AM » |
what is the "film trick"
« Reply #5 on: March 12, 2010, 04:12:57 AM » |
Take a section of 35mm camera film, a couple inches long. Slid it up your forks and under the seal. Work it up and down, back and forth. The little notches in the film will pull out some crud and bugs. Sometimes you get enough junk up there that the seal will leak. Sometimes this is all that is needed for a leaky seal. Give it a day or 2 of riding and it may clear up. If not, then a seal change is in the future.
valkyriemc
NE Florida
« Reply #6 on: March 12, 2010, 03:15:37 PM » |
Take a section of 35mm camera film, a couple inches long. Slid it up your forks and under the seal. Work it up and down, back and forth. The little notches in the film will pull out some crud and bugs. Sometimes you get enough junk up there that the seal will leak. Sometimes this is all that is needed for a leaky seal. Give it a day or 2 of riding and it may clear up. If not, then a seal change is in the future. FWIW I "filmed" my left tube two years ago, still good.
Veteran USN '70-'76
sheets
« Reply #7 on: March 12, 2010, 04:31:26 PM » |
FWIW I "filmed" my left tube two years ago, still good. Me too. Yrmv,
Valkpilot
What does the data say?
Corinth, Texas
« Reply #8 on: March 12, 2010, 05:11:12 PM » |
Take a section of 35mm camera film...
Cameras have film?
« Reply #9 on: March 14, 2010, 07:35:39 PM » |
Cameras have film?
I think its the clear protective thing you pull off the LCD of a new camera.
roboto65
« Reply #10 on: March 14, 2010, 07:43:02 PM » |
Heheheh flim I used 600 grit paper paperside against the tube of course and slipped it up and ran it back and forth a few times fixed !!!
Allen Rugg VRCC #30806 1999 Illusion Blue Valkyrie Interstate 1978 Kawasaki KZ 650 project
deadvelvet
« Reply #11 on: March 18, 2010, 05:03:40 AM » |
thanks to all ill try it been busy workin nights on an outage havent had time to try the film but im going to so thanks for all the input
asfltdncr
« Reply #12 on: March 25, 2010, 09:02:33 AM » |
Fork seal.Make sure you replace the bushings when replacing the seals.Good time to upgrade springs if you haven't already.They're only about $100 (Progressive).
