January 30, 2026, 12:28:16 PM
draining the carb float bowls?
Topic: draining the carb float bowls? (Read 1995 times)
upjeeper
March 11, 2010, 09:01:56 PM »
when draining the carbs will the fuel come out past the float bowl screws or through the drain tubes?
DFragn
Re: draining the carb float bowls?
March 11, 2010, 09:35:21 PM »
Through the drain tubes unless 1 or more are blocked (unlikely, but possible) and then only through the drain screw openings if you back the screw out too far or completely.
Normal carb drain procedure may produce a few drops of fuel at the screws - nothing significant -
Pete
March 12, 2010, 06:02:40 AM »
Open 1.5 to 2 turns for draining thru the hose.
