January 30, 2026, 12:28:57 PM *
Author Topic: Installing Front Wheel Bearings - Help  (Read 2321 times)
valk2128
Suwanee, GA
« on: March 15, 2010, 07:10:37 PM »
I am about to change the front wheel bearings.
I purchased the tool to pull the bearing outs from Pit Posse Tools.
Without purchasing the Honda tool to put the new bearings in, what can I use to put them back in?
thanks
Joe Hummer
Arnold, MO
« Reply #1 on: March 15, 2010, 07:13:39 PM »
I used a socket large enough to hit the outer race on the bearing and I tapped the bearing in place.
Joe
1999 Valkyrie Interstate
Madmike
Campbell River BC, Canada
« Reply #2 on: March 15, 2010, 07:30:46 PM »
... just m
Joe
as Joe says.... just make sure that you are actually against the outer race of the bearing, if you don't have a socket large enough you can take the old bearing and reduce the OD on a bench grinder enough that it won't get stuck in the bore and then use it as a driver.
Don't allow the outer race to spin while you grind it as you run the risk of the bearing seizing up and ripping your hand apart with the inner race if this happens. Sad Sad
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #3 on: March 16, 2010, 10:27:34 AM »
Can also grind the old bearing down a little on the outside and use it to tap new one in.
Cattman
Franklin, IN
« Reply #4 on: March 16, 2010, 11:23:52 AM »
Put the new bearing/race  in the freezer for 2-3 hours prior to install. Goes in easier when the  metal is contracted. cooldude
Disco
Republic of Texas
« Reply #5 on: March 16, 2010, 11:42:21 AM »
Last time I did mine, it was a sunny spring day and I put the wheel in the sun for a hour and the bearings in the freezer for an hour.  They popped right in.  Quick tap with a large socket on the outer race to ensure they were bottomed, and done.
« Last Edit: March 16, 2010, 11:44:03 AM by Dave in Frisco (TX) » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Larry
Northeastern BC, Canada
« Reply #6 on: March 16, 2010, 12:11:54 PM »
Ditto all of the above and don't forget to put the spacer in before the second bearing goes in.  Smiley
Bob E.
Canonsburg, PA
« Reply #7 on: March 16, 2010, 01:19:25 PM »
And don't forget the spacer... cooldude
