January 30, 2026, 03:29:39 PM *
Author Topic: dyna beads  (Read 4158 times)
boubou
maniwaki,québec,canada
« on: March 18, 2010, 09:56:56 AM »
I'm running a car tire(205-55-16) and i 'd like to know if any of you are using DYNABEADS, and how much onces do you put in it. Thank you
Warlock
Magnolia, Ms
« Reply #1 on: March 18, 2010, 10:40:09 AM »
Running them in mine. I used 3 oz.
David
« Reply #2 on: March 18, 2010, 11:04:46 AM »
The worst mileage I ever got on a rear Cooper Zeon 2XS car tire was 7,400 miles...It had Dyna-Beads in it ( 3 oz. )....I think they are no more than snake oil.
Disco
Republic of Texas
« Reply #3 on: March 18, 2010, 11:50:06 AM »
+1 on Dyna Beads!  I'll put them in my Continental Vanco when it gets mounted along with my new front.  That will be 6 tires with Dyna Beads.
I had to put 3oz in my Avon Cobra rear to equal the amount of lead I took off.  12,000 miles and counting with slight cupping and mild flat spot.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
JimL
Naples,FL
« Reply #4 on: March 18, 2010, 12:02:30 PM »
Dyna Beads worked well for me.
I had a rear Dunlop that developed a severe "bounce" at 35-40 mph.  I later found out the reason was because either the tire wasn't balanced to begin with, or the weight came off somehow.  I put 3 oz. of DynaBeads in the tire, and the problem disappeared immediately.
alph
Eau Claire, WI.
« Reply #5 on: March 18, 2010, 02:17:14 PM »
i have dyna beads in my tires, front and rear, although i don't have a car tire i used two ounces in front and three in back.  i did notice a definete difference in the first 1/2 mile.  as for any ill effects, don't know yet.  i've only had them in for about 2000 miles.  i do wonder if there's any aditional wear on the inside of the tires?  i'll have to wait for when it's time to replace 'em to check.
i have talked to the local good year dealer, he uses them in the big 4x4 truck tires.  he thinks they're a good product, i would think that if he uses them, there must be something to 'em.
Youngsmoke
Las Vegas, NV
« Reply #6 on: March 18, 2010, 03:47:44 PM »
@alph
  I wanted to put them in my tires but was wondering about the amount, what kind of tires do you run?  I have the metzler 880s
roboto65
Conroe,TX
« Reply #7 on: March 18, 2010, 04:37:17 PM »
You cannot go wrong with and I use 2 oz up front and 3 oz in the back!!
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Dodis
'98 Blue & Cream
Texas City, TX
« Reply #8 on: March 18, 2010, 08:41:39 PM »
Good Year Triple Tread and 2 oz. Rock steady up to 99.9999 mph  Evil
VRCC# 27132
mr_dodis(a)yahoo.com
DS#513 GY-TT 205/60   (still waiting for my cookie!)
Steve K (IA)
Cedar Rapids, Iowa
« Reply #9 on: March 18, 2010, 09:56:01 PM »
I put them in both my Valks, front and rear.  Dunlops on one and Metzlers on the other.  Man do they run smooth down the highway.
States I Have Ridden In
YardBoy
« Reply #10 on: March 19, 2010, 06:27:41 AM »
I have the beads front and rear, have some slight vibration 35-40 mph.  Above that they are smooth as silk.  I'm guessing it takes rotation speed (around 40+) for the beads to collect at the right spots to cancel any vibration.  I did not have any notable vibration 35-40 until after the beads.  I think they cause a slight inbalance at slow speeds that can be felt.  At highway speeds with the beads is the smoothest ride I've ridden to date.
Mikey
Winona, MN
« Reply #11 on: March 19, 2010, 06:32:33 AM »
Should be rock steady up to about 125 mph  Grin
Remember folks, street lights timed for 35 mph are also timed for 70 mph
VRCC# 30782
NITRO
Eau Claire, WI
« Reply #12 on: March 19, 2010, 10:03:24 AM »
@alph
He runs E3s. Should be the same for any brand tire for the valk (Metz, Avon, Dunlop, etc.). I don't know about the car tires, though.
When in doubt, ride.
Jack
Benton, Arkansas
« Reply #13 on: March 19, 2010, 10:06:34 AM »
I had my rims balanced 9 yrs ago and have never balanced a tire since.  Never a problem.  No vibration that I can tell.  My tires wear as good as anyone's.
« Reply #14 on: March 19, 2010, 11:28:34 AM »
I hadn't read anything about dyna beads being re-usable, are they?
« Last Edit: May 15, 2012, 08:16:41 PM by gordonv » Logged
PharmBoy
Lawton, Ok
« Reply #15 on: March 19, 2010, 01:01:19 PM »
Been using dyna beads for over 2 years and am well satisfied.  I reused them on the last tire change, but they are somewhat troublesome to fish out of the bottom of a tire so I weighed what I had and added enough to put 2 oz in the front and 3 oz in the rear of the new tires...JTL
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Disco
Republic of Texas
« Reply #16 on: March 19, 2010, 01:58:16 PM »
Yes, they are reusable.
78 CB550K
humshark
Spring Hill Tennessee
« Reply #17 on: March 24, 2010, 11:04:09 AM »
I used the beads to get a LOT of extra miles out of my truck tires before replacement, 5oz/ea tire.
A little common sense here for amounts.  Bigger tire = larger possible weight compensation factors.
If 3oz are needed in a normal rear tire, then I'd likely use 4oz in a larger car tire.  If they are approximately the same, and made well, ( nearly balanced to begin with ) then stick with three.
I lucked out when I ordered my 5lb package, UPS delivered a busted box that leaked little balls all over.  I turned it in and got a new shipment, while the old was declined for return.  I ended up with about 7.5 pounds in all!
check here for usage guidlines http://www.innovativebalancing.com/chart.htm
When the truck tires were replaced - I warned the installers, but it didn't matter.  They were EVERYWHERE!  - and I agree that it IS possible to reuse them, but NOT that easy to get out cleanly!
99 Interstate
05 FJR
97 Vulcan '88' Hacked
Disco
Republic of Texas
« Reply #18 on: March 24, 2010, 01:51:27 PM »
And boy do those little buggers bounce!   tickedoff    2funny
78 CB550K
roboto65
Conroe,TX
« Reply #19 on: March 24, 2010, 04:25:52 PM »
Just like the Superball we had as kids  2funny 2funny
Allen Rugg
VRCC #30806
« Reply #20 on: March 24, 2010, 06:59:17 PM »
Where do you find a larger qty than 16 ozs, that's the biggest I found listed?
« Reply #21 on: March 24, 2010, 07:15:46 PM »
this is from an early thread.
http://www.quackco.com/yttriumstabilizedzirconia.html
humshark
« Reply #22 on: March 25, 2010, 06:44:31 AM »
I had ordered and received mine from Quackenbush Company in Crystal Lake, IL.
An earlier link from last summer had the information on who to call for the orders.  5# "trials" were sold and were a very good deal.  After shipping I thought it ended up being less than $70.  These are a uniform average size 1mm ball if I remember correctly.  -and YES they do bounce!
99 Interstate
05 FJR
Cliff
Manchester, NH
« Reply #23 on: March 25, 2010, 07:34:34 AM »
.86 to .98 mm
Thanks Robert, I've sent Quackenbush an email for a quote for 5#.
Their reply:
"The beads they are buying are our QBZ-58A, which is made of zirconium silicate. ZY beads are made of yttrium stabilized zirconia, and they cost a lot more. We can offer our 0.8-1.0 mm QBZ-58A for the price of $60.00 per quart. A quart contains a little over 5 lbs. We have the beads (QZ-58A) in stock."
I put 400 miles on my new E3 Dunlops today and the tires/balance with the beads is smooth as any I've ever felt. I'm going to buy a quart after I return from InZane next week.
Bon
From another thread.
« Last Edit: March 25, 2010, 07:45:59 AM by Cliff » Logged
VRCC # 29680
roboto65
Conroe,TX
« Reply #24 on: March 25, 2010, 08:11:52 AM »
Yep 60 bucks give or take and they are the .8 to 1 mm got mine and a scale set for a while anyway Oh and I have been dealing too  2funny 2funny first hit is free  2funny 2funny
Allen Rugg
VRCC #30806
Ken 11861
Lunenburg, MA
« Reply #25 on: March 25, 2010, 05:13:24 PM »
I was very sceptical about using Dynabeads but after researching here and balancing many tires the old way many times,  I  finally went with Dynabeads last year. I feel they are great, want to say perfect. I put them in my new front tire last year and it (Cobra) is wearing perfectly. I pulled the weights of my 1 year used rear tire (VenomR) & also put the beads in. The rear tire was already cupped a little (as usual) now it truely is smoothing out. I'm just jodging the Dynabeads now by how well and even the tires will wear, they are balanced very well.
2001 Valk (72,500 5/2011) & 2009 ST1300 (new 5/10)
1FAST6
Sanford, NC
« Reply #26 on: March 29, 2010, 08:14:01 AM »
Just mounted F&R last night and "recycled" my beads.  Easy way to get them out:  Clean a spot ion the inside of the tire about 2" wida all the way across.  Get a regular postal envelope, open the flap and stick some duct tape to it.  Stick the tape on the clean spot inside the tire and open the envelope.  Roll the tire to bring the envelope to the bottom and continue around.  Most of the little critters will roll right into the envelope.  Tap the outside and the rest jump right in!  You can weigh the envelope and add as necessary, in case you lost a few.  Empty the contents of the envelope into the new tire once you get the botton bead on the rim.  Mount the top bead and you're good to go!
