January 30, 2026, 03:28:59 PM *
Author Topic: grinding in transmission coupled with no resistance on clutch?  (Read 3808 times)
upjeeper
« on: March 20, 2010, 02:29:52 PM »
This morning after about 3 hours of fighting with the breather box and other misc problems under the tank I got my bike fired up. It took a bit to get the nasty old gas out of the carbs (i did drain techron into, let it set then out of the carbs). The bike runs pretty nicely when in neutral.
So I did the next natural thing, I squeezed the clutch level and shifted into first. The green neutral indicator light went off but there was a horrible grinding sound like the gears were trying to mesh together but could not. I've never worked on a hydraulic clutch before.
The clutch level has little to no resistance when squeezing. I've already a clutch level bushing on order from bike bandit, should be here in a few days.
Any suggestions?
Thanks much.
Super Santa
VRCC #27029
Houston, Texas
« Reply #1 on: March 20, 2010, 02:37:34 PM »
Check the site glass on the clutch reservoir and see if there is anything showing.
upjeeper
« Reply #2 on: March 20, 2010, 02:41:15 PM »
yup, fluid is showing. I just checked.
Ratdog
Somewhere out West, Which way did I go?
« Reply #3 on: March 20, 2010, 02:41:26 PM »
Hmmm... got a bad feelin'.  Might find uglies in the clutch basket... like rivets which've let loose.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
« Reply #4 on: March 20, 2010, 02:52:40 PM »
1- engine off, put bike in gear and try to move it.  Should not move.
2- Squeeze clutch lever fully and try to move bike (still in gear) - should move, if not either the clutch master or slave cylinder is bad, or there is a lot of air in the system.  (I assumed you had checked the fluid level and the master cylinder reservoir is full)
Jeff K
« Reply #5 on: March 20, 2010, 05:09:06 PM »
What happens when you try to start the bike in gear?
upjeeper
« Reply #6 on: March 20, 2010, 06:47:31 PM »
1. bike does not seem to want to shift into different gears
2. put the bike into first gear and move forward with the engine off, grinding noise, doesn't move easily
3. put the bike info first gear while holding clutch lever in and move forward with the engine off, grinding noise, doesn't move easily. Same as with clutch lever out (hands off).
4. try to start the bike in first gear clutch lever out (hands off) nothing
5. try to start the bike in first gear squeezing clutch lever in horrible grinding noise.
ok, so my first action will be to bleed the clutch cylinder and flush the fluid. if no change then what?
would it be worth getting a master rebuild kit? how do I determine is the master needs to be rebuilt?
« Last Edit: March 20, 2010, 07:49:55 PM by upjeeper » Logged
Ratdog
« Reply #7 on: March 20, 2010, 07:52:45 PM »
When my clutch master cylinder was dieing on me, it worked... is just "creeped" unless I "pumped" the clutch a number of times before stopping at a light... or, pumped the clutch a half dozen times between shifts.  No noises.
« Reply #8 on: March 20, 2010, 08:11:59 PM »
Hollywood had his valk not take 5th gear. Ended up being the u-joint.
upjeeper
« Reply #9 on: March 21, 2010, 04:03:02 PM »
I bled the clutch out this afternoon. It REALLY needed it.
The clutch now works, I can fire the bike up, hold in the clutch lever (which now has resistance) and shift into gear. However when I release the clutch lever the horrible grinding noise is back (when in gear).
If the bike is off, in gear now with the clutch held in the bike will move forward.
Seems to shift up and down through most of the gears but neutral is hard to find.
<insert confused smiley face here...>
help?...
« Reply #10 on: March 21, 2010, 04:10:20 PM »
I'll put my $$$$ on the bob tailed nag.
Clutch basket rivets.
upjeeper
« Reply #11 on: March 21, 2010, 04:19:58 PM »
so I understand clutch basket rivets.
but what do you mean by "bob tailed nag"?
« Reply #12 on: March 21, 2010, 05:41:01 PM »
I think its a referance to the Camp town Lady song. No biggie. I'm no horse person but I think its a short cut tail on a nag.  2funny
Mr.BubblesVRCCDS0008
« Reply #13 on: March 23, 2010, 04:41:13 AM »
Check the coupler on the final drive, I stripped mine out and it sounded like it is coming from the engine end but really was just the coupler and the driveshaft that needed replacing.
Jeff K
« Reply #14 on: March 23, 2010, 05:36:56 AM »
Yeah, I'm not convinced it's the clutch rivets yet also.
Now that the Clutch lever "feels normal" it may not have anything to do with the clutch.
I'd inspect the final drive also.
chip
« Reply #15 on: March 23, 2010, 07:40:48 AM »
Check the drive shaft at the cup, had the splines fail once, knew it had to be the trans. I was never so happy to spend 100.00.
upjeeper
« Reply #16 on: March 27, 2010, 09:49:12 AM »
It appears the pinion cup and driveshaft have worn. It's looking like the following parts from HDL
Mfg Part Number:           41410-MN5-000
Description:         JOINT, PINION for 1997 HONDA GL1500C
Unit Price:         $35.09
#13
http://www.hdlparts.com/fiche_image_popup.asp?fveh=3465&section=148039&year=1997&make=HONDA&category=MOTORCYCLES&dc=2291&name=FINAL+DRIVEN+GEAR
Mfg Part Number:           40201-MZ0-000
Description:         SHAFT, PROPELLER for 1997 HONDA GL1500C
Unit Price:         $100.11
#2 from http://www.hdlparts.com/fiche_image_popup.asp?fveh=3465&section=148048&year=1997&make=HONDA&category=MOTORCYCLES&dc=2291&name=SWINGARM
Mfg Part Number:           91261-ME9-005
Description:         OIL SEAL (27X43X7) for 1997 HONDA GL1500C
Unit Price:         $7.34
#16 http://www.hdlparts.com/fiche_image_popup.asp?fveh=3465&section=148048&year=1997&make=HONDA&category=MOTORCYCLES&dc=2291&name=SWINGARM
Should I tear into my u-joint and check that while I'm at it??
MP
North Dakota
« Reply #17 on: March 27, 2010, 10:28:58 AM »
Yes.
"Ridin' with Cycho"
AussieValk
Gold Coast, Australia
« Reply #18 on: March 28, 2010, 05:17:41 AM »
That shaft price looks expensive. I ordered one last week for $48.01 from HDL.
upjeeper
« Reply #19 on: March 28, 2010, 05:59:11 AM »
that's what I thought, could you find the part number you bought please?
Thanks.
AussieValk
« Reply #20 on: March 28, 2010, 06:36:37 AM »
same part # 40201-MZ0-A00 but it was for a 2000 model, not that it should be any different.
Ok just noticed the difference in the number...A00, not 000 like yours.
« Last Edit: March 28, 2010, 06:38:26 AM by AussieValk » Logged
