January 30, 2026, 02:09:13 PM
swing arm nut cap?
Topic: swing arm nut cap? (Read 2121 times)
CMA_Carl
swing arm nut cap?
March 20, 2010, 05:04:38 PM »
Where can a guy find a swing arm nut cap? Just the chome plastic cap?
thanks
Carl
Valker
Wahoo!!!!
Texas Panhandle
Re: swing arm nut cap?
March 20, 2010, 05:40:40 PM »
Honda Direct Line has them. They are surprisingly cheap.
March 21, 2010, 05:22:43 AM »
Did one of yours disappear?... same thing happened to me, and I saw the replacement halfway
out the other day... other folks were sealing them in with silicone seal, I'm going to try something
like that...
Dave Weaver
Seymour, IN
March 21, 2010, 06:21:41 AM »
Here is a link to what you want. Order item #13 in schematic.
http://www.hdlparts.com/fiche_section_detail.asp?section=148889&category=MOTORCYCLES&make=HONDA&year=1999&fveh=3478
Do unto others as you would have them do unto you.
March 21, 2010, 07:02:07 AM »
My replacement also was sliding out. I wrapped one layer of black tape around it and put it in, that was 4 years ago... Still there, I just went out and looked to make sure.....
Ya'll can tell how much I look MGM over. I look at tire pressure, that the gas valve is shut off, if not I pull 6 plugs before hitting the starter, quick look at all the lights after he is running. Jump on and take off. 1/2 the time I forget to turn the damn gas back on and he stumbles about 4 or 5 blocks from the house. Usually right in the middle of a stop sign right turn take off....... I am slowly feeling the valve now about 3 blocks away from home. Has saved my arse a few times from a drop over in the turn into traffic. Nuf said.
