January 30, 2026, 02:09:40 PM *
Author Topic: New version MagnaCharger, throttle cables  (Read 1890 times)
dreamaker
Harrison Township, Michigan
« on: March 21, 2010, 07:25:02 AM »
I ordered my MagnaCharger and I am trying to get my ducks in a row before the charger gets here to make a smooth transition. Now the new version has the carb. on the back. I have read all over about the throttle cables, " they will work",  "you have to modify the cable", " you have to get custom cables".  I am totally confused, what is the recommended method for the cables. Now keep in mind that a supercharger on a Valk. with faulty cable setup is like lighting a missile under your a$$. Can anybody advise me.
Dan
Murdoc
Englewood, Ohio
« Reply #1 on: March 21, 2010, 08:32:11 AM »
Not sure if there is a recommended length, but that seems to be what worked out for me on my IS.  I just re-routed the stock cables and then measured what I was lacking.
fstsix
« Reply #2 on: March 21, 2010, 01:23:14 PM »
I think what is happening is if you buy the Blower with the Mikuni upgrade it will put your Carb behind the Blower, Unlike the HD Kehin that is on 'top', this is why some are having to extend their cables and has not been a issue in the past, because nobody was running a Mikuni W/O the bypass tube. so if you ordered with the Mikuni looks like the cables will be short. but well worth the time and money to REMOVE that POS Kehin. JMHO
