March 14, 2026, 05:04:10 AM *
Pages: 1 [2]   Go Down
Author Topic: Maintnence questions...  (Read 13755 times)
DrewDanube
Houston, Tx
« Reply #40 on: April 25, 2008, 08:47:54 PM »
Update:
Got the tire mounted, installed.  Cursed the entire lineage of the person that designed the way the panniers bolt on.  Took 3 of us to get them bolted up. (50 bucks for the aftermarket solution is sounding like a great investment at the moment).
With one bag on, took it for a spin.  Low speed was fine except for weird noises.  Either the right nut flange is rubbing because of the bolt not being tight because the bag wasn't on, the brakes need to be re-bed or something is awry in our re-install of the tire/wheel...hoping its not the latter at this point.
Any suggestions?  Its a high pitch squeel during left turns and rear braking...
And into the great beyond I go...
previous bikes:
Suzuki Intruder 1400
KLR650
V-Max
FZ-6
Bandit 1200S
Hyosung Avitar GV0650 (sold!)
Wanderer
The Great Republic of Texas - Dallas
« Reply #41 on: April 25, 2008, 10:21:42 PM »
Update:
Cut the nut cages and reversed the bolt heads thru the fender stays (grab rails)? With the bike on the ground, put two people the size of you and your pillion on the bike and have someone that is very anal check the clearances. ~Jeff
« Last Edit: April 26, 2008, 06:29:54 AM by Wanderer » Logged
More Valk Pics...
had a couple of Valks once upon a time
2004 DRZ400S
2005 GS1200
1978 CB550K
1977 CB550F
DrewDanube
Houston, Tx
« Reply #42 on: April 26, 2008, 06:39:35 AM »
I figured that was next Smiley.  I didn't know about reversing the bolt but love it.  We could get an allen wrench through from the tire side no problem, but never from the outside to check alignment.  I will be buying the rattlebars kit at some point.
previous bikes:
KLR650
V-Max
FZ-6
Bandit 1200S
DrewDanube
Houston, Tx
« Reply #43 on: April 27, 2008, 12:42:04 PM »
Final update, I think...
Its done...the fenders modified to hold the tire (should have gone to a 205/60 instead of 55 if i had known that I was going to have to modify the fenders for sure...but oh well).
Initial rides...rear braking is WAY better, bike feels more solid taking off...both obvious with more contact.  however, I did a bunch of turns and aside from a little firmer hand, it did everything I asked, including almost peg scraping.
Now that its running...my box of buttons for radio and clock aren't working.  I wiggled alot of parts in the process of doing this so I'm going to open up the right side cover and check connections.  wish me luck...at least i am running.
Drew
EDIT: I'll admit that I hadn't read my manual yet, specifically the audio control section.  There is an ON button!  It worked onced I hit the ON button.  Funny how that works... (Battery died while waiting for the tow)
« Last Edit: April 27, 2008, 03:03:29 PM by DrewDanube » Logged
previous bikes:
KLR650
V-Max
FZ-6
Bandit 1200S
Curtis_2Valks
« Reply #44 on: April 27, 2008, 07:20:14 PM »
Yes, Sir. Good to see you chiming in, Curtis! Going on Stan's ride to Meer's Store Saturday, May 3rd?
Jeff I didn't know about it, sounds like a plan. It's been a while since I rode with you guys.  Let's see how I feel after working 12's all this week (I'll probably need a ride more desperately, ha!).
Curtis
Rowlett,TX MOOT #315 VRCC #26023
States I've Ridden
There is no lunch too far, nor any need for a reason other than the journey.
cutter
Plantersville, Texas
« Reply #45 on: April 28, 2008, 08:10:23 AM »
Glad you have the bike back on the road.
DrewDanube
Houston, Tx
« Reply #46 on: April 28, 2008, 09:23:13 AM »
and we made 4 pages Smiley
TY all.
I'm going to do a tech write-up and post it somewhere when I do this again once I have O-rings...Changing the rear tire for dummies (like me)...
Drew
previous bikes:
KLR650
V-Max
FZ-6
Bandit 1200S
« Reply #47 on: May 03, 2008, 12:36:28 PM »
Drew
hehe, I did the same thing with the radio...  Who would have thunk that there would be an ON and OFF button on this thing~!?  Mine was after taking my ham radio back off after supporting a bicycle ride down in Manvel a few weeks ago.  I thought I had unplugged something under the gas tank while pulling the wire back off of the bike.
Hay    Cool
Pages: 1 [2]   Go Up
