January 30, 2026, 02:26:40 PM *
Author Topic: Low tech lift adapter for cali bike  (Read 2048 times)
Youngsmoke
Las Vegas, NV
« on: March 24, 2010, 05:36:34 PM »
Hey all,
   I have a cali model 98 tourer and I am building the low tech (wooden) lift adapter from the shoptalk pages.  I just finished making my cuts in the wood and went to do a dry fit before I screwed everything together and that is when I noted that the evap canister? (a cylinder about 8" long by about 4" in diameter) is in the way down there.  First, is that the evap canister I am seeing under the bike?  I have done the desmog from the instructions in shoptalk but only removed the pair valves and all the extra tubing above the engine.  Can I remove this canister?  or does anyone have suggestions for adapting around it?
thanks all
Hammer
« Reply #1 on: March 24, 2010, 06:22:08 PM »
I too have a CA '98 Tourer. I have a welded adapter which fits fine. I've heard a report on the board that the bike doesn't run right when you remove the Canister until some other plugging was done. For now, just remove the 2 bolts holding it and let it hang to install and use your wooden adapter.
sheets
Jct Rte 299 & 96, Calif.
« Reply #2 on: March 24, 2010, 06:41:31 PM »
Cali guy here with a Cali bike.  I removed said cannister a few months ago to accommodate a lift stabilization device.  I'm not a wrench.  I have the repair manual.  My interpretation of the connections going into the cannister is that the cannister is only filtering outbound vapor before it hits the outside world atmosphere.  I recently blew the cobwebs out of the scoot after a long period of time in dry dock.  I notice no difference in performance in the 30 or 40 miles put on a couple weeks ago with the absence of said cannister.  She still purred like a kitten and roared like a lion.  If there is a wrench in the crowd with a better synopsis of the scenario I'd like to read about it.   sheets
« Last Edit: March 25, 2010, 05:29:24 AM by sheets » Logged
sugerbear
wentzville mo
« Reply #3 on: March 24, 2010, 07:02:03 PM »
2k I/S desmogged cannister off, no difference. BUT, keep all the spare parts as a CYA.
my 2 cents
