January 30, 2026, 03:29:48 PM *
Author Topic: Carb parts I.D.  (Read 2049 times)
Tropic traveler
Silver Springs, Florida
« on: March 26, 2010, 08:04:52 PM »
Cleaning up a Valk with totally gunked up carbs & I need some experienced info on what's what inside. Please excuse my ignorance here, I'm a decent wrench but carb work is my weak suit!
Looking at the pic I am assuming the big jet in the middle is the "main jet" and the smaller one to it's right is the "slow jet". Both of them are slotted and removable. I also assume that they would need to be squeaky clean & the passages under them clean & open.
Am I right so far??
If so, what is the little brass tube to the left of the biggest jet? It does not appear to be removable & I cannot get a wire through it.
I want to get this Valk running great again & learn about Valk carbs along the way.
Thanks!
'13 F6B red for Kim
roboto65
Conroe,TX
« Reply #1 on: March 26, 2010, 08:39:55 PM »
If I am not mistaken and well I have been wrong only once before  uglystupid2 that is a vent to the outside well in to the aircleaner if you look on top of the carb in the plenum you will see some holes and one of those goes to that it just allows equal pressure as the fuel rises and falls in the bowl..
« Last Edit: March 26, 2010, 08:42:09 PM by roboto65 » Logged
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
9Ball
« Reply #2 on: March 26, 2010, 08:49:57 PM »
Am I right so far??
Thanks!
When you unscrew the jets, the long one is the secondary and the short one is the main.  You'll see numbers on them, 35 and 100 respectively.  I prefer to replace these rather than try to clean them.  At $5/each it is much cheaper than having to pull the carbs again if you don't get them squeaky clean..  Feel free to pm if you need any help.
John
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
SgtBunny
"Don't be a Lemming!" - MCC
Kingwood, WV
« Reply #3 on: March 29, 2010, 06:37:57 PM »
If you are going to replace your 35's and need some 38's which several people have used in their bikes, let me know.  I have a spare set I am not going to use now.
VRCC #29625
'98 Tourer
