January 30, 2026, 02:26:47 PM *
Author Topic: rear wheel binding after install  (Read 2597 times)
charlie1200
« on: March 27, 2010, 01:01:38 PM »
Installed my new tire on the bike and come to find out it was binding.Ended up taking the wheel back off and final drive was bound up. I had loosened up the final drive nuts a little bit like they say and the wheel seemed to slip in alright but after tightening everything down it was binding.Ive put on the rear tire before with no problems,this time no. anybody have this happen to them? I put that star wheel with the 5 pins back in and tried to turn it ,even with a pry bar but it wouldnt budge.Any ideas of what I need to do?
Bone
« Reply #1 on: March 27, 2010, 01:31:23 PM »
Did it drop into gear ?
alph
Eau Claire, WI.
« Reply #2 on: March 27, 2010, 01:50:23 PM »
yeap, me too.  had the same thing happen, don't know what i did.  rode it around the block and it went away.  i'm planning on taking my rear wheel apart one of these rainy days to check it out.  hopefully i didn't ruin anything too expensive.
it also makes an odd sound when i bank either way.  don't know.  my boss always says, don't fix it unless it's broken.......
let me know what you find out, i'll return the favor if i find out first......
al.
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: March 27, 2010, 01:56:37 PM »
charlie, did you loosen up the final drive nuts enough for the final drive to align itslf with the wheel flange?  You must.  Loosening up the nuts a little bit isn't enough.  Torque the axle nut first then the final drive nuts.
Marty
charlie1200
« Reply #4 on: March 27, 2010, 02:47:07 PM »
Pretty sure its in nuetral,turned on the key and the green light came on.yea, I loosened the 4 final drive nuts a good 1/8 of an inch,even though they say just finger loose.Alph,was yours binding too?Did you put it back together and ride it? I want to get some ideas before I start taking things apart. lol
Warlock
Magnolia, Ms
« Reply #5 on: March 27, 2010, 03:16:12 PM »
Check and make sure you aren't putting the universal joint in a bind. If you try and turn the wheel without the shocks hooked up it will bind and will not turn.
David
« Reply #6 on: March 27, 2010, 04:05:06 PM »
     Confession time.  I've have been the only person to change the tires on my Valk. I've never loosened the final drive nuts, never had a problem with alignment, never had any binding. Just saying...,...
« Reply #7 on: March 27, 2010, 04:07:19 PM »
The wheel WILL NOT TURN with the swing arm lowereed.....until you get the shocks attached the u-joint will be bound up
« Reply #8 on: March 27, 2010, 04:08:50 PM »
It only takes once to get the splines misaligned and then they tear up fast and you will be hunting a new pumkin
« Last Edit: March 27, 2010, 04:10:47 PM by Chrisj CMA CR3M » Logged
charlie1200
« Reply #9 on: March 27, 2010, 04:25:03 PM »
Ahh! ok. That makes sense now.I did have the swingarm really low to get the wheel in.And I tried to turn the wheel before I connected the shocks.When I changed the wheel out before I didnt loosen the final drive nuts and it worked out fine,lucky I guess.Tommorrow I'll make sure the bike is down before I try to rotate the tire. Thanks guys.I decided to go to the darkside and I put on the goodyear triple track-looks good on my chrome rims.
alph
Eau Claire, WI.
« Reply #10 on: March 27, 2010, 04:40:47 PM »
i seriously think my problem is a misplaced thrust washer.  not sure if i put it before the spline or after.  why i think that is because i helped out a friend with his rear wheel, and i was extra careful with his, more so then with mine, and after putting on the wheel i realized it was wrong so we took it off and then read the book!!  rode his bike several miles and it sounded fine compaired to mine.
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #11 on: March 28, 2010, 02:42:42 AM »
Me too! I've never heard of loosening them to change tires.
AussieValk
Gold Coast, Australia
« Reply #12 on: March 28, 2010, 05:09:00 AM »
Before learning the procedure and doing it myself I watched two dealers remove my rear wheel and replace tyres without loosening those nuts, hell, on the second one I had to ask them to grease the spline.......so I no longer let anyone else work on my bike.
