doubletee
VRCC # 22269
Fort Wayne, IN
« on: March 28, 2010, 05:49:09 AM » |
I'm not the most mechanically inclined.  I have seen several suggest replacement of the normal carb springs with IS carb springs. First, what function do carb springs provide (throttle return?), and second, how are the IS springs different from the standard/tourer springs?
« Reply #1 on: March 28, 2010, 06:33:43 AM » |
I'm not the most mechanically inclined.  I have seen several suggest replacement of the normal carb springs with IS carb springs. First, what function do carb springs provide (throttle return?), and second, how are the IS springs different from the standard/tourer springs? Generally thought of as "softer" springs allowing the vacuum operated slides to open quicker, hopefully resulting in faster motor response to throttle beatings. ***
six2go #152
« Reply #2 on: March 28, 2010, 06:57:26 AM » |
Tony: I did that mod several years ago. It works. When ya "wack the throttle", you go forward.......Right now!
« Reply #3 on: March 28, 2010, 04:36:03 PM » |
+1
Bandit
« Reply #5 on: March 29, 2010, 07:11:37 AM » |
2 beers and 1 handed,but well worth the Hour it will take.If I can do it any one can.  Bandit.
SgtBunny
"Don't be a Lemming!" - MCC
Kingwood, WV
« Reply #6 on: March 29, 2010, 07:31:56 AM » |
If you need a set of I/S springs let me know. I bought a set and come to find out do not need them.
VRCC #29625 '98 Tourer
« Reply #7 on: March 29, 2010, 08:21:20 AM » |
1 beer per carb Tony!  Nah its simple. Take your little carb tops off, pull out the little black diaphram thing-carefull not to tear it, pull out the old spring, replaced in reverse order. Less then a hour.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #8 on: March 29, 2010, 08:51:20 AM » |
1 beer per carb Tony!  Nah its simple. Take your little carb tops off, pull out the little black diaphram thing-carefull not to tear it, pull out the old spring, replaced in reverse order. Less then a hour. Thanks, Brian! I think even I can do that much.
SgtBunny
Kingwood, WV
« Reply #9 on: March 29, 2010, 06:35:13 PM » |
While you are changing your springs, are you going to go ahead and change your jets...a little more involved but if so, let me know. I have a set of 38's I am not going to use now.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #10 on: March 31, 2010, 10:34:37 AM » |
No, I don't plan to mess with the jets.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #11 on: April 11, 2010, 05:02:10 AM » |
New springs installed (about a 30-minute job). Took her for a test ride. I can't say I notice a huge improvement, but certainly no worse. Might be a touch quicker. Probably the easiest mod I've done, though.  Thanks for the instructions and help! SgtBunny - pleasure doing business with you!
