January 30, 2026, 03:29:01 PM
dan-marc fuel valve
Topic: dan-marc fuel valve (Read 2153 times)
groundpounder01
dan-marc fuel valve
March 28, 2010, 06:09:08 AM »
For you guys who are runnin a dan-marc, Did you splice both wires off the valve to both wires on the coil? Maybe some of you picked up a chassie ground of the bike somewhere. I have mine in already, just compareing instalation.
MP
North Dakota
Re: dan-marc fuel valve
March 28, 2010, 08:18:53 AM »
I ran the ground to one of the screws on the braces between the carbs. Hot to the coil.
MP
"Ridin' with Cycho"
X Ring
VRCC #27389, VRCCDS #204
March 28, 2010, 09:01:36 AM »
Which wire? The black/white common to all three coils or the other one?
Marty
MP
North Dakota
March 28, 2010, 09:56:48 AM »
It was NOT the common one. Just pull a wire off, turn on the key, to "on", and see if the wire is hot. If so, use it. Splice in.
MP
"Ridin' with Cycho"
tlanz
March 28, 2010, 05:44:50 PM »
I tied mine into the 'supply side' (+) black/white wire on one of the coils and the 'ground side' (-) to one of the coil
mounting
bolts. Don't tie into the yellow (w/red, white or blue stripe) coil wire, it's the 'fire' signal from the ECM.
X Ring
March 28, 2010, 07:02:56 PM »
Thanks tlanz!! I already did a search and discovered it for myself. In one of the threads on this from last year there was a link to Chet's schematics on the Rattlebars website. Chet marked the black/white wires as positve so that is what I tapped. Thanks again.
Marty
