January 30, 2026, 03:29:57 PM *
Author Topic: Rear Tire Change  (Read 2101 times)
22Dasher
Shelbyville, TN
« on: March 29, 2010, 07:10:45 PM »
I'm having a new Avon tire put on my Valk tomorrow by a local shop and would like to know what do I need them to do while the rear hub is off and what do I tell them to look for? Bike has 28000 on it so any advice from you guys would be helpful.
James
« Reply #1 on: March 29, 2010, 07:32:40 PM »
Replace 3 orings and thrust, if needed. Lube everything including drive shaft ends.
wiggydotcom
Yorkville, Illinois
« Reply #2 on: March 29, 2010, 07:55:21 PM »
James
Hopefully, they will do a good job of balancing...which is, find the heavy spot of the rim and then the heavy spot of the tire and put the tire's heavy spot 180 out..that way it uses less weight.
If this is the first tire change you've been involved in, take it easy the first 50 miles or so until the new coating gets scrubbed off--easy on the cornering.
VRCC #10177
VRCCDS #239
tlanz
« Reply #3 on: March 30, 2010, 03:45:58 AM »
Download Download Carl Kulow's complete Valkyrie Maintenance Manual here: http://www.valkyrieriders.com/ShopTalk/ValkMaintManAcrobatPDF.pdf   cooldude Pages 17-21 cover front & rear wheel removal and rear spline lube. One thing NOT covered in there is the 'elusive third o-ring'.  See here for those details: http://www.valkyrieriders.com/ShopTalk/Elusive%203rd%20O-Ring.htm
I believe the o-rings are critical; I always replace them unless I find they are perfect (which isn't as often as one would hope).  Use care too, they are easily damaged during reassembly. Particularly the 'inner' ones (you need not ask).  tickedoff  Also, be sure to lube the splines "reeel good".  I've been using 60% Moly Paste (Honda's) for years (I'm on my 6th change now) with excellent results. However, others here have differing opinions.  I only recommend you research the topic and form your own opinion.
« Reply #4 on: March 30, 2010, 11:39:48 AM »
A good shop will know to use Bel Rays grease or an equivalent(not Honda's moly paste). Tell them to loosen the 4 bolts that attach the drive unit to the swingarm and retighten after torquing the axle nut. I'm assuming they are doing all the work. They'll charge more for a drive unit removal and shaft greasing.
