January 30, 2026, 03:28:58 PM *
Author Topic: Clear Coat on polished forks  (Read 2176 times)
greggh
OMAHA NE
« on: March 30, 2010, 10:46:23 AM »
Has anyone polished their forks and triple trees and had them clear coated?
Can I do it myself or is there a place to take them to have them done ( body shop )?
Once I get them done I would like to keep the appearence of the polish with effertless care.
Just trying to get some ideas.
Gregg.
« Reply #1 on: March 30, 2010, 11:13:18 AM »
Some have polished them and you might find a shop to do it for you. If you disassemble the forks, have them clear powdercoated to protect the polish. Honda has a coating which chips off after years of bugs and gravel chips. Sanding or oven cleaner should remove the original coating.
Disco
Republic of Texas
« Reply #2 on: March 30, 2010, 06:47:47 PM »
I've heard and read good things about Glisten PC from Por 15.  It's sprayable and brushable and recommended for polished metals including aluminum.  They have a water based prep solution that is highly recommended.  I sure hope it works, I'm about to use it on a pair of wheels I'm polishing.
http://www.por15.com/Clearcoats/products/6/
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
greggh
OMAHA NE
« Reply #3 on: March 30, 2010, 07:29:12 PM »
The Glisten was mentioned to me by a friend of mine.
I going to check the cost of having them clearcoated, will then base my decision at that time.
Thanks for the input.
Gregg
