January 30, 2026, 03:29:44 PM *
Author Topic: Rear wheel full of water - Why  (Read 2522 times)
Colin
My old job
Orba, Spain
« on: March 30, 2010, 10:59:04 AM »
After I got my wheels back from polishing yesterday I thought I had better replace the bearings before refitting them. Pulled the fronts no problem pulled the single bearing rear no problem. Pulled the double row rear and found it rusty on the inside and that the spacer tube was also rusty on the outside. Picked the wheel off the bench and about half a cup of water poured out.
How did it get there? What do you think? Is this unique or something I need to watch for in the future?
The splines and final drive are all fine as is the axle shaft, only 17k miles on a 96 standard.
Colin
VRCC Espana
My Bumble Bee re-build
Jeff K
« Reply #1 on: March 30, 2010, 11:10:54 AM »
Water from wet sanding?
Colin
My old job
Orba, Spain
« Reply #2 on: March 30, 2010, 12:30:32 PM »
Don't think so as it had been in there for some while (the rust) and none in the front wheel.
Colin
VRCC Espana
tlanz
« Reply #3 on: March 30, 2010, 12:45:33 PM »
Do you use a pressure washer to give the beast a bath? Could be one explanation.
Colin
My old job
Orba, Spain
« Reply #4 on: March 30, 2010, 02:03:13 PM »
I have even washed it let alone pressure washed it,  Wink  but I have only owned it since September and it has been in pieces since then. I doubt that the previous owner did as it was in such a mess BUT maybe the shop that I bought it from did.
Oh well must be JOOTT.
Colin
VRCC Espana
Spirited-6
Nicholasville, Ky.
« Reply #5 on: March 31, 2010, 06:37:29 AM »
I would bet the water is from a air supply that has not been drained / blown out for a long time. My compresser will spit out water if I don`t drain ever so often.  Roll Eyes
Spirited-6
PAVALKER
Pittsburgh, Pa
« Reply #6 on: March 31, 2010, 06:41:29 AM »
Huh???  I think he is talking inside the wheel (behind the wheel bearings/seals) and not in the tire area.  Undecided
John
lee
Northeast Tennessee
« Reply #7 on: March 31, 2010, 07:10:11 AM »
Any possibility it could have been a Katrina bike?
Time is not what is taken but what remains.
C. Drewry
Colin
My old job
Orba, Spain
« Reply #8 on: March 31, 2010, 07:33:06 AM »
Thanks guys for the thoughts and suggestions.  cooldude
It was new in 96 and taken to the UK in 96 so it was not a Katrina bike and it was water in the centre of the wheel behind the bearings NOT in the tyre.
Any way not to worry it seems as though it was a pretty unique problem and as I am now only a fir weather rider  Wink I hopefully won't have to worry about it again.
Colin
VRCC Espana
X Ring
VRCC #27389, VRCCDS #204
« Reply #9 on: March 31, 2010, 09:41:47 AM »
And here I thought you owned a Valk not a Hardley.
Colin
My old job
Orba, Spain
« Reply #10 on: March 31, 2010, 11:04:39 AM »
OOPS that spell checker not working again Roll Eyes  Smiley
You wash your mouth out now Marty saying a word beginning with H on this forum.  2funny
Colin
VRCC Espana
X Ring
« Reply #11 on: March 31, 2010, 11:21:21 AM »
Spell checker is fine.   angel
Marty
